Solid centre or spring clutch- what are the differences for my needs?
Old Feb 8, 2019 | 09:44 AM
thugsbryan's Avatar
Default Solid centre or spring clutch- what are the differences for my needs?
hi guys just want to know Wat clutch best for a daily driven boosted b16 making around 330whp
I don't want a clutch that it too stiff on my foot as i drive d car daily. Shud I go with solid centre or a spring centre clutch? And what's the advantage and disadvantage of both?
Old Feb 8, 2019 | 10:08 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default re: Solid centre or spring clutch- what are the differences for my needs?
Definitely go with a sprung clutch. The unsprung chatter and are much harder on drivetrain parts and not needed for that power level.
Old Feb 8, 2019 | 10:11 AM
thugsbryan's Avatar
thanks.i was thinking sprung but this was after I bought a solid center cause last clutch I had one of the springs fell out an got stuck in between the pressure plate. But if i install the solid centre will it do any damage over time on a daily driver?
Old Feb 8, 2019 | 12:36 PM
Txdragon's Avatar
Answered already... See below..
The unsprung chatter and are much harder on drivetrain parts.
Old Feb 11, 2019 | 04:41 PM
motoxxxman's Avatar
solid [unsprung] clutch discs are FOR RACE USE ONLY. This does NOT mean a street car that gets raced occasionally, it means TRACK ONLY cars that only use wrinklewall tires at all times.
Street cars require sprung clutch discs.
Sure, some people use solid discs on the street. sometimes it works, sometimes it doesn't. fact of the matter is, using an unsprung clutch on the street WILL damage your gears, axles, bearings, etc etc.
A spring popping out of the disc is the result of a faulty disc and/or doing high rpm clutch dumps. which are ridiculously stupid and accomplish absolutely nothing.
Also to note, clutches are rated by torque, not HP. And they are rated by crankshaft torque, not torque measured at the wheels on a dyno. Meaning if your car makes 300ft/lbs of tq on a dyno, it's making closer to 350 at the crank, and you will want a clutch rated for 350+tq.
Lastly, don't let anyone tell you that sprung clutches can't hold torque. I daily my car, and abuse it several times every day. Currently making 420tq at the wheels (460-500 tq at the crank). Sprung clutch, zero issues ever. I am not kind to my car.
Old Feb 11, 2019 | 04:50 PM
thugsbryan's Avatar
Thanks man, this has shed some light, I will have to sell this solid centre I have an buy a spring clutch
Old Feb 13, 2019 | 02:56 PM
TheShodan's Avatar
Moderator
yes you will, sir.. wow.
KimChiKid
Jan 21, 2008 01:27 PM
carblegal
Dec 3, 2005 10:18 PM
MayhemSi
Sep 29, 2004 11:06 PM
JBBNJ609
Jul 18, 2003 11:03 PM
GDM Z28
15
Apr 2, 2003 10:47 PM
