How do I run a Water cooled turbo on a B18C1 Block?
Hey guys I've been searching and searching and have seen alot of different opinions. I will be running a water cooled turbo on my gsr and it's my first time, i always used only oil. My question is if I can feed from the water pipe and the other to the plug in front the block. The plug under the exhaust manifold. Or also my engine has the iacv eliminated, could I use both those lines ?
Moderator
Re: How do I run a Water cooled turbo on a B18C1 Block?
That's one way of doing it, yes. But there are other alternatives for kits already being made for water-cooled turbos for Honda B-series VTEC.
B&R Fittings Water Cooling Kit
