Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Blowoff Valve Vacuum line location - Intake manifold or another source?
Old 07-18-2018, 04:47 AM
Default Blowoff Valve Vacuum line location - Intake manifold or another source?
I have a quick question. Im going go be running my vaccum hoses just like this setup here. Only problem is my blow off valve (turbo xs type h rfl) only has one port. Should i just tee off or what should i do?
Vryantec is offline
Old 07-18-2018, 04:49 AM
Default re: Blowoff Valve Vacuum line location - Intake manifold or another source?
Or would using this set-up be better? Still having the bov issue and this one is routed to the intake.. a little confused. Also im using a manual boost controller.
thanks guys
Vryantec is offline
Old 07-18-2018, 05:58 AM
Balor_Gr's Avatar
Run it on the intake manifold. Thats the first place the low pressure exists. After the butterfly.
If you route it before th butterfly it will never open because it will just see boost when you let of the gas
Balor_Gr is offline
Old 07-20-2018, 12:20 PM
Default Re: Blowoff Valve Vacuum line location - Intake manifold or another source?
I tee it with the wastegate and have it going to the intake manifold after the butterfly.
SpiderX1016 is offline
Old 07-21-2018, 02:36 PM
Txdragon's Avatar
^^^ That right there.
Txdragon is offline
Pman92
09-19-2007 04:59 PM
CleanLikeJdm
07-03-2006 07:32 PM
all_out_jdm
03-19-2006 06:54 PM
1.8
12-26-2004 09:38 PM
anguish
06-07-2004 06:54 PM
Quick Reply: Blowoff Valve Vacuum line location - Intake manifold or another source?
  • Ask a Question
Question Title:
Description:
