Troubleshooting: spark plugs destruction - damage to cylinder head 2004 1.6 litre
Spark plug exploded outside - Honda Civic 1.6 2004 - Damaged thread on the alloy block. Solution?
re: Troubleshooting: spark plugs destruction - damage to cylinder head 2004 1.6 litre
Pull the head and take it to a cylinder head shop. They can tell you whether or not it can be repaired. If it isn't too bad, they can likely put a thread insert in and you'll be good to go.
Helicoil or new head. Basically the only 2 options available on this.
Re: Troubleshooting: spark plugs destruction - damage to cylinder head 2004 1.6 litre
Yeah that's correct, the spark blown out - never found it - and the threads on the head block of my Civic 1.6L 2004 are damaged. I cannot find another used head block to replace so I need to use the Helicoil. Can anyone recommend me the right product(s) to buy before I do the job? I guess my Civic 1.6L (D16W7 ???)
is made of aluminium cylinder head block. I need all the necessary tools to buy. The size of the spark is M14 x 1.25 x 19 ".
Thanks again!
Thanks again!
parts stores have spark plug thread repair kits. So do all the major tool trucks.
And it's called a cylinder head. Not a block. The block is the bottom half of the motor, totally different part.
Moderator
I may be out on a limb, here, but, from Honda1664's responses, he/she may not be from the U.S. and therefore may have some difficulty in obtaining resources for items that we in the U.S. may assume to be simple to obtain, like, well, other cylinder heads. If Honda1664 would be so kind as to fill in the location information in his/her profile, we might be of some additional assistance.
busta7777
02-09-2011 04:01 PM
prjctCIVIC
03-18-2003 12:35 AM
