Low Compression b16 Cams?
Old Jul 31, 2019 | 12:50 PM
MastaFlyMason's Avatar
Default Low Compression b16 Cams?
Setup is:
b16a2
8:1 pistons
Turbonetics 5857
Cast manifold
Rocket motorsports cams/retainers
Currently have the stock b16 cams in but while I'm in there putting in the springs and retainers I was planning on putting some cams in. I have a set of Rocket Motorsports M21KE stg 4 cams, and a set of Delta 272's. Could also get my hands on a set of stock GSR cams. Which cam would be best? Not sure if the rocket cam will be any good with the 8:1 compression ratio of the engine.
Old Jul 31, 2019 | 01:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Low Compression b16 Cams?
Why did you go so low on compression ???
Old Jul 31, 2019 | 04:26 PM
Short block came from a car I parted out. I realize now I should have swapped the pistons out.
Old Jul 31, 2019 | 06:34 PM
TheShodan's Avatar
Moderator
Get more pistons
Old Jul 31, 2019 | 10:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Originally Posted by TheShodan
Get more pistons
Yes, get more pistons.
Old Aug 1, 2019 | 03:50 AM
Balor_Gr's Avatar
Setup is:
b16a2
8:1 pistons
Turbonetics 5857
Cast manifold
176-T to maybe wake up your mid range.That cast manifold comboed with 8:1 wont help your out of boost daily driving too.
Id say go for a better manifold first like a mini ram or a ramhorn. Cast mani will make a setup more unefficient out of boost.
If you can find somone that can mae a mini-eq like lovefab it will be the best.
Old Aug 1, 2019 | 03:54 AM
extremeracer's Avatar
B16's don't like low compression - it makes them terribly lazy at low to mid-rpm. A set of 10:1 forged pistons will be great. I don't know the details of the two cams you reference, so cannot help out with that one. Based on a quick Google search the Rocket's are quite large with 250 degree at 0.050. They should make for strong top-end power if your turbine housing is large enough and you not using a log-type manifold.
Cams that size need some runner length to minimise inter-cylinder interference
Old Aug 1, 2019 | 05:39 AM
Thanks guys, I'm going to look into getting more pistons
Old Aug 1, 2019 | 05:51 AM
Autoworks's Avatar
Get more pistons
^this
Good choice, compression will make a night/day difference.
g23cg5
Nov 15, 2013 04:58 AM
Sabres_e
21
May 15, 2010 12:50 PM
esurds
Feb 11, 2010 07:42 PM
costar
Mar 9, 2006 09:30 AM
DJslepton
11
Sep 29, 2005 07:22 PM
