Did I just make a mistake buying 2001 B18c5 ITR valvesprings? - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Old 01-11-2019, 12:47 PM
Default Did I just make a mistake buying 2001 B18c5 ITR valvesprings?
So I am building a b18c1 with S2 tuner stg1 cams, Eddy Vic X intake manifold, ported GSR head, and a cxracing turbo kit that I already had so that is what I'm using for FI. So my question is my goal is to make some in 4XXwhp range not sure what rpm I'll be spinning but I purchased the valvesprings mentioned in title my question is will these springs be enough for my build? Or did I just throw money in the wind?
1sic95accord is offline
Old 01-11-2019, 02:02 PM
turboLScrx's Avatar
Default Re: Did I just make a mistake buying 2001 B18c5 ITR valvesprings?
there is a trade off, the type R springs will allow for an extra 500 rpms of rev but that might be counter reacted by the added boost pressure. I’m guessing that 8k shifts and up to 15 psi would probably be safe. The more boost you add the less effective the springs become in turn losing the ability for higher rpms, treat it like timing, for every pound of boost over 10psi I would reduce redline by 100rpms. I might be completely wrong and someone might correct me on this
turboLScrx is offline
Old 01-11-2019, 02:52 PM
Originally Posted by turboLScrx View Post
there is a trade off, the type R springs will allow for an extra 500 rpms of rev but that might be counter reacted by the added boost pressure. Iím guessing that 8k shifts and up to 15 psi would probably be safe. The more boost you add the less effective the springs become in turn losing the ability for higher rpms, treat it like timing, for every pound of boost over 10psi I would reduce redline by 100rpms. I might be completely wrong and someone might correct me on this
thanks for the quick response.
Old 01-11-2019, 03:14 PM
turboLScrx's Avatar
Ďalso, Iím not sure how aggressive the turner 2 cams are, that could also reduce the max rpm also since there is more lift, that might be a tech all to Skunk2
Old 01-11-2019, 07:05 PM
Moderator
TheShodan's Avatar
unless it's a big turbo,(61lbs/min +), don't. if you're staying skunk, stick with Tuner1.
TheShodan is offline
Old 01-11-2019, 07:16 PM
Old 01-11-2019, 07:28 PM
Moderator
TheShodan's Avatar
in reference to turboLScrx's comments
Old 01-11-2019, 07:54 PM
turboLScrx's Avatar
nm
Old 01-11-2019, 07:56 PM
turboLScrx's Avatar
I miss read and thought he said he had turner 2 cams
Old 01-13-2019, 12:08 PM
turbociv910's Avatar
i put valve springs in pretty much every car for piece of mind.. cheap insurance
turbociv910 is offline
Old 01-13-2019, 12:18 PM
yeah just purchased Blox 10300
Old 01-13-2019, 03:00 PM
Moderator
TheShodan's Avatar
In God's name, why THAT company? You're better off taking a chance with the stock ITR over that nonsense.
Old 01-13-2019, 03:45 PM
budget build
Old 01-13-2019, 04:11 PM
turboLScrx's Avatar
After you buy retainers, it’s not much more to get the supertech or skunk2.
Old 01-13-2019, 04:50 PM
After you buy retainers, itís not much more to get the supertech or skunk2.
budget build no ti retainers
Old 01-13-2019, 05:41 PM
turboLScrx's Avatar
if your trying to stay at or below factory redline, just use the Type R springs, they are proven Honda parts. Just remember budget build have limits, just because they are budget don’t always mean they are better than what you had already. I Know a guy that made over 700hp on a stock GSR head, he just stayed within factory redline. I personally would keep stock valves. I’d just talk with people that has done what your about to do and make sure they had good results and if you can’t find people that use the parts your trying to use.... there is probably a reason why. Looks like You came here wanting everyone to just agree with you, but we try to help and sometimes that means telling you what you don’t want to hear
Old 01-13-2019, 06:17 PM
if your trying to stay at or below factory redline, just use the Type R springs, they are proven Honda parts. Just remember budget build have limits, just because they are budget donít always mean they are better than what you had already. I Know a guy that made over 700hp on a stock GSR head, he just stayed within factory redline. I personally would keep stock valves. Iíd just talk with people that has done what your about to do and make sure they had good results and if you canít find people that use the parts your trying to use.... there is probably a reason why. Looks like You came here wanting everyone to just agree with you, but we try to help and sometimes that means telling you what you donít want to hear
I wasn't wanting anyone to agree just looking for help. After comparing blox specs to others springs they should do as I. Seat pressures etc. Thanks for the quick response.
Old 01-13-2019, 06:21 PM
I was not advocating to put cheap in there.. blox litterly does zero r and d. Supertech, skunk, ferrea.. anything else lol
Old 01-14-2019, 08:51 AM
Moderator
TheShodan's Avatar
budget build
Budget build to destroy itself pretty fast. This is a mistake. Not everything on a spec sheet is the same material quality, use, etc.
You just made the simple very complicated in your quest for "budget build". :smh:
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
