Can we Discuss Effective Compression,Elevation,Fuel type?
Old Dec 30, 2018 | 06:50 AM
sikefcrx89's Avatar
Loved
Default Can we Discuss Effective Compression,Elevation,Fuel type?
Ok. So It's been a while since my last turbo charged car. While it was a paltry entry level system with moderate goals for the time (Think TurboEdit). Included are screen shots of the same build,only different compressions
I am currently researching everything for my new turbo charged project.
I am going to be using E85.
My Elevation is 1558ft. Which changes my Static Compression ratio.
Had planned on 10.1:1 which at my elevation turns into 10.03 with an Effective ratio of 19.64:1 at a moderate 15 psi
This could be the difference in 500+hp or falling short
The Other option I have is 10.8:1.
Which puts my Static (Using B16 Head in both cases) to 10.9:1
and pushes my Effective to 21.41
I know plenty of builds are running way more extreme compression than I am even in some cases as a street duty
Mine will not be a daily driver,but I would like to enjoy as often as possible when the weather is nice.
My question is how much Effective Compression is too much with my chosen choice of fuel? Or am I just being a worry wart?
all the while hoping to enjoy the car for 50-60k or more before any real work would need to be done.
Old Dec 31, 2018 | 05:23 AM
sikefcrx89's Avatar
Loved
Default Re: Can we Discuss Effective Compression,Elevation,Fuel type?
Doing some more reading,it looks as if the marginal gain from my would be 10.03 to 10:9.1 while using e85 would take away a ton of safety margin. So ragged edge without a safety net that could potentially last,or give myself a margin of error and whatever it makes is whatever it makes..
Old Dec 31, 2018 | 08:26 AM
Txdragon's Avatar
If using E85, I would be a bit less concerned with higher compression than 93 pump.
Old Dec 31, 2018 | 08:33 AM
sikefcrx89's Avatar
Loved
Being I can go from my 1558ft to a short 20 min drive away and be 2300-3200ft in elevation I am leaning more to just play the better safe than sorry card.
Old Dec 31, 2018 | 08:43 AM
Txdragon's Avatar
So punch that elevation into ZW and see what it looks like.
Old Jan 2, 2019 | 02:14 PM
sikefcrx89's Avatar
Loved
Effective only drops the higher the altitude.
at 10.9:1 at 2300ft it goes from 21.51 at 1558ft to 21.11 and at 3200ft it drops to 20.75 from a base where my home is located at 1558ft.
I am looking for a clean comparison of Effective compression and Elevation. 3/4 of the time will be semi flat ground with a +/- of 1-200ft. So E85 with the 10.9:1 runs safely at effective compression listed? Tuning will play a real aspect,but tuners are hours away under a separate set of circumstances.
Zeal Does Not factor in Fuel Type
Old Jan 2, 2019 | 02:19 PM
Txdragon's Avatar
I'd be less worried about compression and more about the elevation changes itself. That's gotta play hell with A/F maps.
Old Jan 2, 2019 | 02:20 PM
sikefcrx89's Avatar
Loved
I am reading 15-16.1 Static. Maybe there are some folks here that a higher comp setup that can shed light..
Old Jan 2, 2019 | 02:22 PM
sikefcrx89's Avatar
Loved
Why I am kind worry warting. Elevation change will make the car richer,so being ragged edge and planning out the drastic elevation changes could be a hindrance.
Old Jan 2, 2019 | 02:24 PM
sikefcrx89's Avatar
Loved
One of the elevation changes I will be fighting. Highest point here is 4397ft
30 Mins from my place
https://en.wikipedia.org/wiki/Shenandoah_Mountain
Old Jan 2, 2019 | 02:54 PM
Txdragon's Avatar
because compression lowers with elevation, I wouldn't see an issue with the 10.9:1. Because you'll be using E85, I wouldn't worry about higher compression. Because you'll be changing elevations throughout your travels in this car, your tune is the biggest concern.
Old Jan 2, 2019 | 04:05 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
You will be fine with that compression ratio at any altitude on a turbo engine on e85. Don't worry man, that is plenty in the safe range so I wouldn't sweat it.
Old Jan 2, 2019 | 04:09 PM
Txdragon's Avatar
^^ Info from a tuner!
Old Jan 2, 2019 | 04:15 PM
sikefcrx89's Avatar
Loved
I will contact a couple guys and get some more input. Not saying I wouldn't take him at face value,but this is the last Honda I ever do.
DC2man
Dec 7, 2007 05:15 PM
94typeR
Mar 27, 2007 08:03 PM
tpb18b1
Jun 8, 2005 10:30 AM
Boostage
Apr 11, 2005 07:11 AM
SiRLudeVtec
Mar 21, 2005 10:07 AM
