Troubleshooting: Car is reaching positive boost pressure, but car NOT going anywhere
Hey guys. I need some help with this one cause it's never happened to me before and I can't figure it out. And before the trolls start with their comments, YES, I have searched and read and investigated the forums, as well as Googled my *** off. I sit behind a desk 8 hours a day, so it's not-a-thing for me to utilize the search button/engines, but I'm not finding the answer. I have a b16 built for boost. Greddy b series turbo kit. 550cc injectors. Hondata v3 w/ bluetooth. The problem I'm experiencing is that under load, the car is NOT moving. Its barely trolling along. It IS boosting so I know its NOT a boost leak. As a matter of fact, I gunned it down the block and the boost gauge shot to 15 psi (signal source is the intake manifold), but the car feels as if its only pushing 2 psi. You can HEAR the turbo screaming as the car is going down the block. I've checked everything and cant figure out the issue. The ignition timing as well as mechanical timing is dead on. All injectors firing properly. 125 psi across the board on the compression check (low comp pistons). I've checked the plugs, couplers, everything!. This isn't the first turbo honda I've built (its actually the 3rd...maybe 4th...or 5th..kinda lost count LOL) but I've never had this happen before. I was considering replacing the stock MAP sensor with a Hondata one just to see if that was the issue. But the stock map sensor shouldn't prevent the car from boosting properly at 5lbs, so I'm looking for any insight,suggestions, or experiences such as this that any of my fellow HT'ers might have.
re: Troubleshooting: Car is reaching positive boost pressure, but car NOT going anywhere
First thing that comes to mind would be check your cam timing. Second thing, is it tuned or just on a basemap? Are you running something weird on it like a missing link?
Agreed with above with timing issue. I had an identical issue with my old Nissan CA18 and turned out to be a bad cam angle sensor. Check there as well..
My question is: how are you reading 15 psi in Hondata on a stock map sensor?
OP, when was the car tuned ??? Has it run properly before and now has issues or has it always been this way ???
Ghetto guessing:
Do you have CAT on the car?
Do you did a leak test on the charge piping? Turbo WILL make whatever target boost even with a big leak.
It WILL overcome the boost leak unless the leak is huge. It just uses ALOT more exhaust energy wastegating less gasses. This will rob a lot of power.
Who did the tuning? Is the ignition advance normal in the program?
I though about the cam timing. and rechecked it yesterday. it is spot on. Its an old tune that im actually using for a basemap. I built a Si 2 years ago and kept the tune. Sold the car. Now building the same set-up again, but this time in an EF as opposed to an EM1, so I used the old tune for the basemap. Havent even gotten it to the dyno yet because of this issue im having. And no, im not running a missing link. havent done that in at about 15 years LOL
I'm not reading 15 psi in Hondata on a stock map sensor... where'd ya get THAT idea from? As far as the cam angle sensor, it's possible. I AM using some sort of aftermarket distributor (obd1), and if I'm not mistaken the cam sensor is actually built into the distributor, unlike obd2, where it is an external piece. The ignition timing is fine tho, but I guess I can swap the dizzy and see if I get anywhere
Ghetto guessing:
Moderator
It's good that you have the boost gauge hooked up to the intake manifold. That's the best source to see if you're ACTUALLY getting boost pressure, as opposed to strictly reading it from a laptop that sees the map sensor.
I'll make the presumption that this car has been properly tuned (is that a fair assessment? If not, and you're running on a basemap, this could pose a problem.)
What's important is whether or not the kit you've installed ALWAYS had 15psi of boost pressure, and the symptoms recently started, or if you've just now put this together, and it NEVER got to 15 psi.
-Is the kit new, or used? what was the condition of the turbocharger whence you obtained it?
-Was there anything recent that happened to the car before putting this kit on? Any overheating, or rebuilding of the engine required before installation?
-Which turbocharger are you using? the TD04-15G or the TD05H-18G? This makes a difference...
At this point I'm looking to vacuum setup on the wastegate, boost control, vacuum sources and possible leaks that can't be seen through a leak tester (MAP cars don't give the same results as MAF cars like Subarus), or possibly turbocharger damage.
More information is needed at this point, and this is beyond a Google search. This is physically understanding how you've set the car up.
Re: Troubleshooting: Car is reaching positive boost pressure, but car NOT going anyw
If the gauge (and s300) wasnt reading boost, then I WOULD test it
On hondas many times you dont hear the hissing sound of a leak.You can make some holes on the charge piping and the turbo will still create boost, but this will create a lot
of pre turbo pressure because the turbo will wastegate too little gasses trying to work hard for that boost target. That creates what we call back pressure and it steals power.
If the boost gauge deviates too much it might even be an exhaust leak also.
Moderator
Explain your reasoning on how having one is relevant to the loss of boost pressure. (Just Curious).
Not to sound like an old ***, but I haven't run one is 18 years. That's for my tuner to utilize. Depending upon tuning, he may not be running that "rich" to show any additional symptoms. If the turbo is running lower than standard pressure, the fuel trims would be as though he's only at the reduced level of boost pressure anyway. AFR wouldn't be affected negatively.
Premium Member
There is no specific reasoning. I'm just trying to get the whole picture here, like you. OP has yet to confirm or deny it's a boost leak issue. Until he does, I'm just analyzing what I'm reading here and thinking of other possible causes.
I still believe something revolving around the dizzy/cam sensor ordeal anyhow..
Moderator
The gauge sees the actual manifold pressure increase, The EMS is using a MAP sensor that hopefully is calibrated (and in the correct place) to similar manifold pressure. but that will be based upon a voltage reading. It's best if BOTH the MAP sensor and mechanical boost gauge come at least in close proximity of the same reading. But I'd never truly depend upon the MAP sensor to determine actual boost pressure. All it takes is the wrong selection box (i.e. 2.5BAR MAP vs. 3.0 BAR MAP ) to get an entirely different reading from what the sensor sees. With the Mechanical gauge, (Assuming it's at the correct source) you stay consistent to know what's really going on.
OP, did you use the exact same parts in your Si as you are using now in the EF ??? Same engine, turbo manifold, turbo, charge piping, intercooler, fuel pump, fuel injectors ??? It is possible that simply tuning the vehicle will cure the issues that you describe, but the more specific information that you can provide here, the better chance we can offer a viable solution to help you diagnose and solve your issues if they exist - outside of the tune. Also, if you intend to run more than 10 psi of boost, I suggest you swap the stock MAP sensor with a bolt on type 4-BAR MAP sensor... you can bolt it on at the dyno three minutes before you tune.
Car not being tuned is a problem also. You shouldn't be "gunning it" unless you know whats going on with ignition timing and AFR in the MAP
Moderator
The gauge doesn't really have anything to do with tuning... the purpose of inquiring about a gauge is that the OP stated that he was "seeing" 15 psi AND was using a stock MAP sensor at this time... and a stock "B" series MAP sensor will only read about 10 psi, so in effect, it is not possible to see 15 psi on his datalog.
No way in hell I would be hitting 15lbs on a basemap, same setup or not it could be starving for fuel and leaning out causing **** power. Without a wideband your gonna just keep guessing unless it's something obvious. I've seen two 100% identical setups in two different cars need very different mapping in the tune.
Much back and forth in regards to this issue with no update from the OP anyways.. **shrug**
