How to install 3 port oil catch can
Guys I'm a bit confused.i have a 3 port sealed oil catch can to put on my turbo b16 but I'm not sure how to route the hoses.
The can has 2 holes for in and 1 for out.how would I route the hose from my pcv and the port from my valve cover to it so that the fumes are recirculated into the engine?or do I leave one port out to atmosphere? Do I connect the vacuum that the pcv hose was connected to the can also or not?
Re: How to install 3 port oil catch can
Buy this one and thank me later its plug and play and super easy to install. That can you have is complete **** and most likely not baffled or has everything needed to replace the OEM PCV system.
ect-import-honda-b-series-vtec-oil-breather-can-kit-streetpush-lok-fittings/
https://www.youtube.com/watch?v=pKW16jU306k
Ok just watch the video and copy how they hooked up the vacuum hoses. Might have to cap the center or one of the ports unless its for a drain which I doubt.
O.G. triple O.G.
^^^ I have a similar CC in my car. The petcock wasn't the greatest and started to leak so now it's draining downwards via 6AN braided line.
schpiel
07-09-2007 08:57 PM
