Installing skunk2 pro 1 cams. Quick settings?
Old Apr 18, 2019 | 02:43 AM
Tharshan's Avatar
Default Installing skunk2 pro 1 cams. Quick settings?
Hi!
I bought a set of Pro1's November 2018, and I'm about to install it. I know I should degree them, but I'm not able to do that, and also my friend, who can, dont have time, and I need the car running.
In my search I found this thread: https://honda-tech.com/forums/forced...EWoF6fanupg35A
In there is a link were someone is claiming that later generation cams are ment be set at 0. Is this True? Or should I follow the +1.5/+2 setup?
Some spec:
B18c with benson sleeves
84x89
CP pistons
Pauter X rod
B18c6 head
Ferrea valve train with stock size valves
Old Apr 18, 2019 | 04:06 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: Installing skunk2 pro 1 cams. Quick settings?
Originally Posted by Tharshan
Hi!
Some spec:
84x89
CP pistons
Pauter X rod
B18c6 head
there is no correct answer without doing the cam degreeing unfortunately, every engine is different. If I had put my pro 1 cams in without doing the degree work I probably would have damaged valves and it never would have performed correctly. I personally would advise learning how to do it right and take the time to do it as I did. The last time I did mine it took around 4 hours start to finish. The worse part is you must lock vtec to be able to perform this task
Old Apr 18, 2019 | 11:04 AM
TheShodan's Avatar
Moderator
Agreed with above. Unlike some of the Tuner series, the Pro Series do not have "Quick Settings", as every engine is different to where having the engine degree'd is best for you. sorry.
Old Apr 18, 2019 | 12:30 PM
fotis2000's Avatar
I think the last series pro 1 they don’t need to degree.
Old Apr 18, 2019 | 02:03 PM
TheShodan's Avatar
Moderator
Some like to live life dangerously.
Old Apr 18, 2019 | 04:38 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
those cams could cause damage or a loss of power without being done properly.... like you said, some people live dangerously and will never get the money they spent to perform
Old Apr 18, 2019 | 09:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
All cams should be degreed for proper operation and maximum performance. Every engine is different.
Old Apr 19, 2019 | 01:28 AM
fotis2000's Avatar
Guys I mean that you can put it at 0 places
Old Apr 19, 2019 | 07:38 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Yes, you CAN set the cam gears simply to 0/0. But this doesn't make the settings correct. There are too many factors that alter the cam to crank relationship, and degreeing the cams makes up for all of these variables. If you want it right... you gotta DO IT RIGHT.
Old Apr 19, 2019 | 07:57 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
exaxtly. 0 isn’t 0 anymore with the new cams
Old Apr 19, 2019 | 03:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Yes, zero isn't zero anymore if you have done ANY of the following: Milled the head, sleeved the block, decked the block, replaced the timing belt, replaced the tensioner, replaced the camshafts, installed aftermarket cam gears, replaced the head gasket, used a thicker or thinner head gasket, line bored/honed the crank main journals, line bored/honed the cam journals and even lastly, having a worn or stretched timing belt.
Old Apr 27, 2019 | 06:46 PM
Tharshan's Avatar
I got the cams degreed
Old Apr 28, 2019 | 03:54 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
smart move
b1620vtec
19
Oct 25, 2014 02:18 AM
crxb16a90
Feb 8, 2010 11:24 AM
Sp00nFed EM1
23
Jul 11, 2009 02:13 PM
egsi32
19
Jan 6, 2005 06:44 PM
MaaseyRacer
Jul 4, 2004 08:57 PM
