Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
Old 01-29-2019, 01:53 PM
Default Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
Hello, I have a 2001 Acura integra GS-R, I've had the car for some time now and decided I definitely want to boost it, this is my first ever build so I'm a lil lost about some of the water hoses that are orginally on the motor for it being stock, I'll post some pictures so you can see what I'm talking about, please forgive me if my info is terrible but I'll be willing to answer anything or post more pictures please just let me know and thank you.
Chubludc2 is offline
Old 01-29-2019, 03:08 PM
turboLScrx's Avatar
Default re: Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
There are many forms of turbo charging a car, some people do it the cheapest way possible but that seems to always require maintenance and failure and others will spend the extra money to do things the correct way with quality parts and have better/longer lasting results...... What type person are you? This will help people recommend what you need to get going with your project
turboLScrx is online now
Old 01-29-2019, 06:25 PM
I have a list of parts, I'm pretty well invested, and I'm still purchasing parts lol the list will be longer then this soon enough
-skunk2 ultra street intake manifold (stage 1)
-skunk2 70mm alpha series throttle body
-57mm Borg Warner t4 turbo
-speedfactory top mount turbo manifold
-1000cc ID injectors
-chipped p28 on chrome
-skunk2 composite fuel rail
-aeromotive fuel regulator
-4bar map sensor
-g-plus oil cooler kit
-intercooler (with pipping)
-grams oil filled fuel gauge
-AEM 320lph fuel pump
-AEM high flow fuel filter
-ATI super damper
-skunk2 half core radiator
Old 01-29-2019, 06:51 PM
turboLScrx's Avatar
ĎI miss read your post a little, but your list of parts looks like a very solid start
Old 01-29-2019, 07:07 PM
Yeah it's taken me a bit to get them but slowly but surely lol I also taken the liberty to upgrade my fuel to a -6an fuel line.
Old 01-30-2019, 02:28 PM
Default Re: Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
What are your goals for power? From your list, I'm guessing somewhere around 500 hp
Crashmaster91 is offline
Old 01-30-2019, 06:34 PM
Yes 500hp fingers crossed, I also was talking to a local mechanic, and referred this shop to me. https://cylindersupportsystem.com
He also mentioned buying double double valve springs and titanium retainers, and CP pistons, acl bearings, piston rods ARP main studs, and basicly ARP everything, so I'm in the process of tearing down the motor at the moment. So that's basically why I'm asking the questions of what do I do with some of these oil and water lines and so on and so forth, and also getting a hondata-s300-v3, and not entirely sure of a clutch and flywheel. The mechanic also mentioned cams and cam gears, so any further information is greatly appreciated.
Old 01-30-2019, 06:43 PM
turboLScrx's Avatar
im hoping to have my block back from CSS within the week, they do amazing work and the block should have no problems holding the power you want. Iím in the process of doing probably everything your asking about, have you went through my topic? ( making my return to the fold ) Iíve been asking question and getting answers for 4 months straight, my topic might help you get started
Old 01-31-2019, 12:31 PM
yeah I was told about them (css) and I've been checking them out and I'm liking what I see they have fast cars out there and they got a great price, and I'll also look into your thread see what I can learn from it thank you
Chubludc2
11-01-2018 09:03 AM
bukydc5
07-10-2008 05:16 AM
speedhawaii
Hawaii & Asia-Pacific
09-15-2007 01:48 PM
iBrandon
10-17-2005 08:00 PM
drdavidge
05-02-2002 04:02 AM
Quick Reply: Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
  • Ask a Question
Question Title:
Description:
