Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Troubleshooting:Swapped a b20 w/ b16 & changed turbos.Black smoke results
Old 10-12-2018, 02:21 PM
Default Troubleshooting:Swapped a b20 w/ b16 & changed turbos.Black smoke results
Swapped my b20 with a b16 and changed turbos. I had the engine installed in another vehicle and it wasn't smoking at all. Engine has good compression. I put on a brand new turbonetics turbocharger. Oil drain looks good. Now when I start it I get excessive smoke through the exhaust. I don't think it's fuel as my AFRs are sitting in the 11 range. Turbo is brand new, I'm not sure what to think. I may pull the turbo off and see if it is still smoking, what do you guys think? I got rid of the old PCV system and have 10an fittings on my valve cover. I don't have a catch can yet they are just open now for testing would that cause an issue? Car doesn't want to idle either
MastaFlyMason is offline
Old 10-12-2018, 02:58 PM
IndyTeg's Avatar
Default re: Troubleshooting:Swapped a b20 w/ b16 & changed turbos.Black smoke results
What color is the smoke? If the smoke is blueish, you're burning oil. If its black, youre running rich. Have you had a retune since your engine/turbo swap?
IndyTeg is offline
Old 10-12-2018, 03:16 PM
Smoke looks black. Wouldn't my AFRs read rich if that were the case. On cold start AFR's were around 10.5-11. Still running the same tune but i'd think it would be close enough (60 trim turbonetics to 57 trim, b20 to b16)
Old 10-12-2018, 03:27 PM
turboLScrx's Avatar
i had a brand new turbo poor oil out the exhaust once, it wasnít a cheap eBay turbo either. I pulled the down pipe off and found my problem.
turboLScrx is online now
Old 10-12-2018, 03:33 PM
is there supposed to be a pic attached?
Old 10-12-2018, 05:28 PM
O.G. triple O.G.
NVturbo's Avatar
Your old tune is for a B20 and now you're running a B16. Get it retuned. That's a start....
NVturbo is offline
Old 10-13-2018, 05:15 AM
Txdragon's Avatar
Default Re: New setup smoking
10.5 - 11 AFR is usually what you'd see at WOT.. And these are on the fat side. Even cold start, these are pretty rich.
I'd certainly agree with those that say retune and see what happens next.
Txdragon is offline
Old 10-13-2018, 12:16 PM
turboLScrx's Avatar
Default Re: Troubleshooting:Swapped a b20 w/ b16 & changed turbos.Black smoke results
no, I need to remove a old signature from when I joined in 2001 thatís not available anymore
Old 10-13-2018, 01:33 PM
I switched to a b16 basemap seems to have helped a bit. I'll throw the car the rest of the way together and get it to a tuner and see if it clears up. Thanks!
Old 10-15-2018, 04:37 AM
Chance EG's Avatar
This. Also, you changed from a 2.0L to a 1.6L, and changed the turbo... Your old tune is completely invalid.
Chance EG is offline
Old 10-16-2018, 12:38 AM
extremeracer's Avatar
10.5's at idle are way too rich, the 400cc loss in displacement and airflow would cause that. Idle AFR should ideally be >12.0. OEM's usually target 14.7 on idle
extremeracer is offline
Old 10-16-2018, 05:32 AM
Txdragon's Avatar
14.7 is ideal on 91-93, but somewhere in the range of 13.8:1- 15.5:1 is good at idle.
Txdragon is offline
Old 10-16-2018, 10:30 PM
OP, you could likely just pull somewhere in the range of 10-15% from the overall fuel trim in your old tune and get it running well enough to get it to a tuner. No boost until it's retuned though.
Aradin is offline
  • Ask a Question
Question Title:
Description:
