Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
What size injectors would be best for a b18a1/b1 turbo build
Old 04-07-2019, 09:55 PM
Default What size injectors would be best for a b18a1/b1 turbo build
Hi guys I'm trying to figure out what size injector would be best for my b18a1 build I have a fish scaled crank wiseco 8.6:1 com 8.3:1 compression pistons golden eagle rods apr2000 rod studs and bearing for the bottom end a b18b1 head with forged valves and springs with 282 turbo cams with a ported intake and a 70mm skunk throttle body I have a 60 trim turbo trying to get the best build out of it my first turbo build so I need a little help?
Richardvr1 is offline
Old 04-08-2019, 03:24 AM
DaX
DaX's Avatar
Default Re: What size injectors would be best for a b18a1/b1 turbo build
Your horsepower goal will determine your fueling needs. There are lots of fuel injector sizing calculators on the internet. Make sure you give yourself some safety margin on duty cycle.
DaX is offline
Old 04-08-2019, 04:42 AM
Txdragon's Avatar
^^ This..
If you're just looking for an answer to a question, get 1000cc and call it a day.
Txdragon is online now
Old 04-08-2019, 07:03 AM
Man U FTW
Schister66's Avatar
Assuming T3/T04e 60 trim, you're capped at about 450whp, so with that you need about 6cc/whp.
450 x 6cc = 2700cc total
2700cc / 4 injectors = 675cc minimum.
With that, i'd go for either 720s or 880s. If you plan to make more power in the future or if you switch over to e85, it might make sense to pick up a set of 1000s right off the bat.
Schister66 is offline
Old 04-08-2019, 09:22 AM
K20.ek's Avatar
Originally Posted by Txdragon View Post
^^ This..
1000cc FTW!!
K20.ek is offline
Old 04-09-2019, 02:44 AM
O.G. triple O.G.
NVturbo's Avatar
1000cc + E85
NVturbo is offline
  • Ask a Question
Question Title:
Description:
