How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
Old 12-24-2018, 05:02 PM
goseth's Avatar
Default How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
looking to turbo my b18a1 with a t3/t4 57 trim would 440cc injectors be fine? or bigger?
Old 12-26-2018, 10:48 AM
footwork mastery
.Grimace's Avatar
Default re: How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
Good question, you're likely the first person ever to try turboing a B18 with 440cc injectors so a search will likely return nothing. Go forth carefully brave man
Old 12-26-2018, 12:04 PM
goseth's Avatar
nah man plenty of people done this i’m sure but i’ve searched and searched oh what fuel injectors sz i would need and i seen someone has used 440cc but i’m trying to make sure.
Old 12-26-2018, 01:50 PM
footwork mastery
.Grimace's Avatar
Wow very tough. I searched “turbo b18a 440cc injectors” and found so many threads with info and dyno numbers I didn’t know what do to with myself.
Old 12-29-2018, 04:11 AM
O.G. triple O.G.
NVturbo's Avatar
OP, you need to buy some knowledge.
Old 12-29-2018, 04:21 AM
Autoworks's Avatar
You'll want to search further and look at fuel types (assuming pump gas here), power goals, and application.
Can you put a 440cc injector in while using a "T3/T4 57 trim"...yes. The actual question would be how much power would the 440cc injector support.
Old 12-29-2018, 05:21 AM
turboLScrx's Avatar
I’m running 450cc injectors on my gsr engine and I’m at around 80% duty cycle and around 300whp. The dyno I was on showed 274whp. Like the above stated, all about your power goals
Old 12-29-2018, 08:11 PM
JRCivic1's Avatar
What is your fuel pressure set at ???
Old 12-30-2018, 05:50 PM
turboLScrx's Avatar
Default Re: How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
I think I had it set around 50 as a baseline
oneforce
05-24-2007 10:43 AM
tweekerz
05-03-2006 07:26 AM
DailyBlown
08-03-2003 08:00 AM
egg
02-15-2003 11:29 AM
95c1v1cs1
02-10-2003 07:09 AM
Quick Reply: How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
