FPR spraying fuel! Help.
Old Jul 13, 2005 | 07:14 PM
jBj's Avatar
jBj
Default Flow tested injectors, now motor runs horribly
I just got my injectors flow-tested at a shop. Came home, put them in with new o-rings and plugged everything back in, I had to remove my FPR to access the 3rd fuel rail bolt. Now when i turn on my ignition fuel is leaking out, i will remove the injectors again and make sure they are good, but fuel is spraying like 3 feet out of my FPR. What could cause this? There is no sort of a gasket that i removed... the bolts are tight.
I have an AEM rail with RC 440cc injectors, this is on my 95 GSR manifold with a stock FPR.
Thanks for any help
Modified by jBj at 10:26 PM 7/17/2005
Old Jul 13, 2005 | 07:17 PM
rioninja's Avatar
Default Re: FPR spraying fuel! Help. (jBj)
should be an o-ring on the fpr. Cant remember for sure, its late and i've been drinking
Old Jul 13, 2005 | 07:23 PM
lucidvtec's Avatar
the stock FPR has a o-ring between the FPR and fuel rail
Old Jul 14, 2005 | 08:08 PM
jBj's Avatar
jBj
Default Re: FPR spraying fuel! Help. (rioninja)
Thanks guys, found the ring..it fell off when i removed the fpr.
Another question:
As I said I got my injectors flow tested, 2 were running rich 2 were lean at idle. We figured that if i put the select ones at the rich/lean parts of my rail, it would even out the flow. All I did was remove my ecu and injectors, test them, put them back in in a different order and plug my ecu back in. Now my motor is running horribly and wont even hold idle.
Do you think I need a retune from switching around my injectors? Nothing else was changed.
Thanks
Old Jul 15, 2005 | 12:34 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">We figured that if i put the select ones at the rich/lean parts of my rail, it would even out the flow. </TD></TR></TABLE>
Would this mess with the way my motor runs? After I switched around the injectors to the different spots on the rail, accordding to the rich/lean ones, I didnt retune. Should i need to?
Any help will be appreciated!
Old Jul 16, 2005 | 02:12 PM
jBj's Avatar
jBj
any input?
Old Jul 17, 2005 | 03:26 PM
jBj's Avatar
jBj
bump one more time for an answer
Old Jul 17, 2005 | 06:06 PM
HiProfile's Avatar
If all they did was flowtest them, it shouldn't matter. If they cleaned/balanced them too, you'd retune. Are you running opened or closed loop? Closed loop should compinsate for any different AF's. It'd be best to reset the ecu if it does need to relearn for the injectors.
Old Jul 18, 2005 | 04:13 PM
jBj's Avatar
jBj
Default Re: FPR spraying fuel! Help. (HiProfile)
Thanks for the reply. i found out today they did run brake cleaner through them so they were cleaned.. I am running hondata s100b, dont have a wideband or anything like that. So am i closed loop..? Also to rest my ecu can i just unplug it?
thanks
410ruga
Apr 10, 2014 03:46 AM
K-Spec
Oct 25, 2006 02:28 PM
douglas_be
Dec 31, 2003 09:36 PM
ITRfaithful
Nov 1, 2003 01:36 AM
