n00b fuel management question
Old Jul 11, 2005 | 11:48 PM
2k1 GSR's Avatar
Default n00b fuel management question
i have an obd2 gsr...im looking into hondata w/ the boost option. but what parameters do i have to do for my car to use the hondata? do i have to convert to obd1? and do i have to change ecus? help would be aprreciated
Old Jul 11, 2005 | 11:52 PM
97hb's Avatar
Default Re: n00b fuel management question (2k1 GSR)
Get an obd2b-obd1 harness, obd1 ecu, and the hondata and you should be set.
Old Jul 12, 2005 | 12:21 AM
2k1 GSR's Avatar
Default Re: n00b fuel management question (97hb)
which obd1 ecu? thanks
Old Jul 12, 2005 | 12:25 AM
rsintegra's Avatar
http://www.hondata.com/engines.html
I think you can find your answer there.
Old Jul 12, 2005 | 07:37 AM
adseguy's Avatar
Default Re: n00b fuel management question (rsintegra)
find a tuner, you need to speak with him as well. He/she will tell you all about the process
Old Jul 12, 2005 | 08:01 AM
FOrSfEd's Avatar
Default Re: n00b fuel management question (adseguy)
I would opt for a p28 ecu
Old Jul 12, 2005 | 01:52 PM
2k1 GSR's Avatar
Default Re: n00b fuel management question (FOrSfEd)
my intercooler piping is made for the stock gsr IM so if i get the p28 wouldnt my butterflys stay closed?
Old Jul 12, 2005 | 02:04 PM
dustin's Avatar
P28 or P72.
w/ P28 you lose IAB control (unless you add the components to the board). so if you are using the stock GSR intake manifold and want IAB control, get a P72 or a P28 that has been "upgraded".
Old Jul 12, 2005 | 02:35 PM
a1320addict's Avatar
Default Re: n00b fuel management question (dustin)
have a obd2-obd1 harness on its way back from xs-engineering...pm if you want it
Akalima
Mar 4, 2007 08:45 AM
SuperImport
Apr 16, 2005 04:22 PM
m3bluegsr
Oct 20, 2003 03:47 AM
B00ST2nR
Mar 12, 2003 06:21 AM
