best turbo manifold for a.c
Re: best turbo manifold for a.c (JDMisGOOD)
i just bought a hytech manifold it lets u kep your PS also. i had a drag gen 3 kit before it worked but i wanted to go tubular.
Re: (lucidvtec)
my old turbo manifold allowed AC and was made locally Billy, could try contacting Bill at Autolab.
It really depends on your power goals and time goals along with what engine you want to do this on. the inlinepro manifold is cast stainless steel, and it has been in the 10s many many times with alot of support for 3in downpipes and allows the AC.
If you like ramhorn, then Full-Race makes a ramhorm AC manifold.
http://www.lovefab.com has the sidewinder manifolds which allow 3in and 4in downpipes while keeping AC.
basicly there is no "best" manifold as there are hundreds of vendors out there, it comes down to what you want to spend and how fast you want to go.
Re: (lucidvtec)
thats just a pick of the kit i just bought havent got it on yet but by the time im done my engine bay will look like that maybe even worse cuz i have P.S. a/c and cruise still lots and lots of stuff to fit into a small engine bay it will be tough but in the end i think it will look great. i recomend the hytech manifold u can put a much larger turbo on with it than the other manifold i had but a new hytech manifold cost 1500 bucks and ive heard u can wait up to a half a year for one to get built. if u want the full kit from them manifold, turbo, DP, WG, dump tube, charge pipe, and air------>water IC is about 7-8 grand depending on what turbo u pick new from hytech i just got mine used for 3400 bucks in awsome shape. and i believe with a hyteck kit u are limited to only T-series turbos but im not sure. good luck
