Why do i need a 3 bar map sensor?? And Do i....
Old Jul 13, 2005 | 03:41 PM
hotimportcrx's Avatar
Default Why do i need a 3 bar map sensor?? And Do i....
im going to get my b16 turbo tuned and i wanna tune it at 15 psi....before when i first turboed it i ran it at the track with an fmu and missing link at 18psi...to get some numbers before i tune it ...now im tuning it and removed fmu but left in the missing link and am going to be using a vafc....BUT someone told me i need a 3 bar map sensor for 15 psi...why is this and do i really need it???????????????
Old Jul 13, 2005 | 03:51 PM
TurboIntegra's Avatar
Default Re: Why do i need a 3 bar map sensor?? And Do i.... (hotimportcrx)
What is your exact fuel setup? Your question is vague because we dont know what you do or don't have.
You say you removed your FMU, but do you have bigger injectors now? The stock map sensor is good until 11psi. You can not run a 3bar map sensor with out some sort of standalone engine management system.
Are you trying to run the AFC hack?
Old Jul 13, 2005 | 03:57 PM
Default Re: Why do i need a 3 bar map sensor?? And Do i.... (TurboIntegra)
i have a walbro 255 fuel pump....450cc injectors....hayame fuel rail and fuel pressure modifier..and yea when i removed the fmu the 240cc injectors came out with it....and yea im going to be tunning it with a vafc....
Old Jul 13, 2005 | 04:32 PM
project dc2's Avatar
heheh you're waiting to blow your motor arent ya ? VaFC hack with 15 psi .. heheh goodluck with that one.
Old Jul 13, 2005 | 04:33 PM
ill try it and if it blows i have another b16 block or ill throw an ls in there or something...besides my block isnt stock ...so it should be able to handle some power...besides its a t3 turbo so its not a huge turbo and if its done right it can be as good as any other tunes....if you look around you can see some people have had great expoerence with this
Old Jul 13, 2005 | 04:38 PM
DeadVet's Avatar
well if your block isnt stock then shell out some money for a standalone or some TIME for uberdata.
wantboost's Avatar
Who is Mr Robot?
Default Re: Why do i need a 3 bar map sensor?? And Do i.... (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">heheh you're waiting to blow your motor arent ya ? VaFC hack with 15 psi .. heheh goodluck with that one. </TD></TR></TABLE>
Old Jul 13, 2005 | 04:44 PM
SOHC_MShue's Avatar
Your just asking to blow your **** up. Pure ignorance....
Old Jul 13, 2005 | 10:28 PM
Default Re: Why do i need a 3 bar map sensor?? And Do i.... (SOHC_MShue)
uhh no...there are good cars on the vafc hack
Old Jul 13, 2005 | 10:30 PM
SOHC_MShue's Avatar
Try running your afc with a 3-bar map sensor and a missing link. It should run great!
Old Jul 13, 2005 | 10:40 PM
i didnt say i was gonna get a 3bar as of right now i have a stock map sensor with a missing link and i was debating removing them and replacing them with a 3 bar...and my question was should i???
Old Jul 13, 2005 | 10:48 PM
SOHC_MShue's Avatar
Your answer is no unless you are going to use some kind of better managment where you can adjust for things like different map sensors. Also if you are going to run the afc hack(not suggested)...then you don't even need the missing link so toss that thing.
Old Jul 13, 2005 | 10:57 PM
so wait if i dont need the missing link or the 3 bar and im running a stock map sensor...is it possible to run like 12- 15 lbs of boost on the hack..
Old Jul 13, 2005 | 11:01 PM
SOHC_MShue's Avatar
i would not advise it. I wouldn't run more than 10 or 11 on the hack. In fact i wouldn't run the hack at all. Its very dangerous and your car isn't going to run that smooth. If you really want to run 15psi or more then you need something better. Since you have a crx i assume you are obd0 and turbo edit would be perfect for you.
Old Jul 13, 2005 | 11:11 PM
yea my original plan was to run turboedit but i didnt think it was better then the hack and nobody around here really knows how to work it...and i have no clur where to get it done in jersey.....and is turboedit better then the hack???
Old Jul 13, 2005 | 11:22 PM
inspyral's Avatar
The hack is exactly that, a hack. No one in their right mind who understands how it works(or fails to work) would run it. Even the guy who originally devised how to do it no longer runs or endorses running it.
Old Jul 13, 2005 | 11:26 PM
Default Re: (inspyral)
yea but i need a tune and have limited options....conveting tp obd1 will cost to much and i need it tuned now
-p28 150
-conversion harness 110
-distributor 150
4 wire 02 sensor 50
then to tune (urberdata up to 300) plus getting ecu socketed and these tings installed
thats like 760 plus "unforseen expenses"
right now i can get the vafc for 275 install it...then tune 150
Old Jul 13, 2005 | 11:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">so wait if i dont need the missing link or the 3 bar and im running a stock map sensor...is it possible to run like 12- 15 lbs of boost on the hack..</TD></TR></TABLE>
no. your hack will run off the map snesor. stock map sensor will only read 11 -12 psi
and to run the hack you need to remove the missing link.
you cannot just wire up a 3 bar n call it a day. the ecu doesnt know what to do with it. ecu programs will scale for the new map and new input values.
Old Jul 13, 2005 | 11:44 PM
lucidvtec's Avatar
you wont be able to tune very much...do vafc even see boost..i think not...i would keep ur old setup till you can afford hondata ems something like that...it's kinda all or nuthin...runnin a standalone you can change ur injectors see boost...stock map is good to 11.63psi..with a standalone you can get a gm 3bar for like 70bux
Old Jul 14, 2005 | 05:32 AM
spiceisler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">yea my original plan was to run turboedit but i didnt think it was better then the hack and nobody around here really knows how to work it...and i have no clur where to get it done in jersey.....and is turboedit better then the hack???</TD></TR></TABLE>
Give Xenocron (Chris) a call. He's in Jersey. Tell him Steve from Brooklyn sent ya!
Old Jul 14, 2005 | 07:16 AM
USDM 4G VTEC's Avatar
get turboedit damnit
i made 180whp on the hack and then
made 234whp on turboedit with just 2 more psi
turboedit supports a 2.5 bar map sensor that will allow to read all the wya up to 21 psi
plenty for you
i have the setup and works wonders
Old Jul 14, 2005 | 07:32 AM
SOHC_MShue's Avatar
No turboedit is 100x better than the hack. Think of it as uberdata for obd0. You will not need to convert to obd1 to use it.
Old Jul 14, 2005 | 09:45 AM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotimportcrx &raquo;</TD></TR><TR><TD CLASS="quote">im going to get my b16 turbo tuned and i wanna tune it at 15 psi....before when i first turboed it i ran it at the track with an fmu and missing link at 18psi...to get some numbers before i tune it ...now im tuning it and removed fmu but left in the missing link and am going to be using a vafc....BUT someone told me i need a 3 bar map sensor for 15 psi...why is this and do i really need it???????????????</TD></TR></TABLE>
step away from the car, slowly.
Old Jul 14, 2005 | 10:03 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Why do i need a 3 bar map sensor?? And Do i.... (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">
step away from the car, slowly.</TD></TR></TABLE>
Old Jul 14, 2005 | 10:16 AM
adseguy's Avatar
LOLOLOLOL...i was waiting for someone to save the day for me
