SX fuel pump install questions?
Old Jul 12, 2005 | 07:17 PM
The Tea-father's Avatar
Default SX fuel pump install questions?
about to install the xs fuel pump part number " SX-18203 Billet 1000hp fuel pump" couple qustions, do i need to get a bigger relay? are the stock relay good enough? if so how big? Also how big should the power wire to the pump be? thanks
Old Jul 12, 2005 | 07:42 PM
Turbocivic94's Avatar
Default Re: SX fuel pump install questions? (The Tea-father)
I used 8 guage wire from alternator with fuse and 30 amp relay. My pump turns on when I turn the key on. This ****** is loud though
Old Jul 12, 2005 | 08:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: SX fuel pump install questions? (Turbocivic94)
i think it would be best to pull from the battery or the alternator. all the buicks i built have the power from the alternator.
Old Jul 12, 2005 | 09:40 PM
SFWD 1934's Avatar
Default Re: SX fuel pump install questions? (boostedcivicsir)
You can use an MSD single pole high amp relay. You can use 10 gauge from the battery with a 30 amp fuse as close to the battery as possible. Then use 10 gauge for the ground from the pump.
Jason
Old Jul 12, 2005 | 11:23 PM
thanks for the info guy, we wired up the stock realy seem to work ok, it's loud as hell lol
siblues
Oct 28, 2014 04:55 PM
Mike Lowwryyy
Sep 5, 2013 03:39 AM
crxb16sir
Dec 14, 2009 09:56 PM
turbo boost
Apr 12, 2007 11:54 AM
