car wont stay runnin....
Old Jul 14, 2005 | 02:56 PM
tony n.'s Avatar
Default car wont stay runnin....
sup fellas
last thread i had was about my rpm jumpin up and down while drivin.....
well the other day i started my car.....the rpm goes up and down at idle....then dies....i changed spark plugs and everything....now it wont stay on....
well last time when i was drivin the rpm goes up and down....then died on me....so i changed the spark plugs....(plugs are black...) and it drove fine for a couple of days...now it wont even stay on.....
people was tellin me my distributor was goin bad....
any help would be appreciated
gap .28 or .30 i tried both...plugs still went foul
setup stock b16a sc61 etc... 295whp 199lbtq....tuned by Tony1
Old Jul 14, 2005 | 04:24 PM
PrettyLude's Avatar
probably your ignitor took a crap on you
Old Jul 14, 2005 | 08:45 PM
tony n.'s Avatar
Default Re: (PrettyLude)
nite bump
Old Jul 15, 2005 | 04:35 PM
tony n.'s Avatar
Default Re: (boosted2cam)
bump someone help ***
Old Jul 15, 2005 | 06:20 PM
HoopsShaw's Avatar
Default Re: car wont stay runnin.... (boosted2cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted2cam &raquo;</TD></TR><TR><TD CLASS="quote">
well last time when i was drivin the rpm goes up and down....then died on me....so i changed the spark plugs....(plugs are black...) and it drove fine for a couple of days...now it wont even stay on.....</TD></TR></TABLE>
Your iacv has problly come loose or has gone bad, if you take it off your manifold there will be a big plastic piece that is inside the dome side at the end. Check to see if this has unthreaded itself. If so, tighten it back up. If it has not, replace it and that should fix it. This is a very common problem with hondas. Hope that helps you out.
Old Jul 16, 2005 | 09:40 AM
tony n.'s Avatar
Default Re: car wont stay runnin.... (HoopsShaw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoopsShaw &raquo;</TD></TR><TR><TD CLASS="quote">
Your iacv has problly come loose or has gone bad, if you take it off your manifold there will be a big plastic piece that is inside the dome side at the end. Check to see if this has unthreaded itself. If so, tighten it back up. If it has not, replace it and that should fix it. This is a very common problem with hondas. Hope that helps you out.</TD></TR></TABLE>
i dont understand what your talkin about....can you plz explain in details for me...will can it be my distributor too?
Old Jul 16, 2005 | 10:47 AM
tony n.'s Avatar
bump!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 17, 2005 | 12:23 PM
tony n.'s Avatar
sunday bump
candyteggy
Nov 10, 2006 02:32 PM
osuperjohno
Jul 31, 2005 05:32 AM
dpine
Mar 27, 2005 05:51 PM
Lo-Buck EF
Jun 2, 2003 12:09 PM
dfoxengr
Jan 15, 2003 06:26 PM
