water temps too high??
Old Jul 14, 2005 | 01:45 PM
Phat_GSR's Avatar
Default water temps too high??
I know its HOT as hell out up here right now, its around 33degrees celcius then around 41 with the humidity. Not sure what the temps should be on my motor but i am seeing around 208.5 when cruising hitting about a high of 211.3
i have a sleeved gsr with the peakboost turbo kit, im using a fluidyne half rad with the cap that came with it, a new thermostat from honda and the motor was just rebuilt with a brand new head gasket.
Are these temps ok??
Old Jul 14, 2005 | 03:54 PM
lucidvtec's Avatar
my ride see temps like that daily...i live in hot as* AZ...i think honda motor were designed to run between 180-220 fareinheit safely..correct me if i'm wrong..
Old Jul 14, 2005 | 03:56 PM
poison's Avatar
Default Re: water temps too high?? (Phat_GSR)
That is fine. If you feel like 211 is too high, then you can also get another thermostat to keep it a little cooler.
Old Jul 14, 2005 | 04:41 PM
nfn15037's Avatar
Default Re: water temps too high?? (poison)
Get some Redline Water Wetter and run 50/50 mix of Honda coolant and distilled wate.
Old Jul 14, 2005 | 04:46 PM
Phat_GSR's Avatar
Default Re: water temps too high?? (nfn15037)
ok, i wasn't sure cause i never seen the temp in numbers before. I just picked up some royal purple stuff gonna try that.
gt35rSI
Jul 28, 2009 01:20 PM
G2_Fella
Jun 26, 2008 08:29 PM
DC5_lov3r
10
Sep 2, 2007 06:13 PM
UnrealSpeed
23
Aug 19, 2003 11:52 PM
05 600RR
Jul 17, 2002 11:56 AM
