replace all 5 motor mount inserts? es + prothane?
Old Jul 12, 2005 | 10:21 AM
SneezR's Avatar
Default replace all 5 motor mount inserts? es + prothane?
I was going to purchase the es motor mount inserts for my gsr which is for the lower 3 torque mounts.
I also noticed that prothane makes inserts for the top 2 (left and right mounts)
Should I get all 5? or just the es inserts?
PS I have read up on jimfabs but I wanna keep all of my teeth in tact
Modified by SneezR at 3:45 PM 7/12/2005
Old Jul 12, 2005 | 11:05 AM
Finland's Avatar
I replaced the left, right and rear motor mounts/inserts on my car with ES units. I left the two torque mounts stock...the drivetrain is virtually rock-solid. I really doubt that changing the stock torque mounts will make any difference. At the time I bought mine, only Spoon was manufacturing the torque mounts in poly, I don't believe anyone else makes them.
Old Jul 12, 2005 | 11:50 AM
SneezR's Avatar
why do you doubt that the two upper prothane mounts wouldn't make a difference than stock?
Old Jul 12, 2005 | 11:56 AM
mike1114's Avatar
Default Re: (SneezR)
The two upper mounts aren't really for front to back motion from the motor, more side to side, they do help with a little front to back motion though.
Aside from more vibration, I doubt you would see a large difference from upgrading those two mounts also.
For a cheap alternative, just fill in the tranny mount with window weld. The mount near the timing belt, not much you can do.
Old Jul 12, 2005 | 11:59 AM
PM-Performance's Avatar
Default Re: replace all 5 motor mount inserts? es + prothane? (SneezR)
Idid all of them and absolutely loved it.
Old Jul 12, 2005 | 05:00 PM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezR &raquo;</TD></TR><TR><TD CLASS="quote">why do you doubt that the two upper prothane mounts wouldn't make a difference than stock?</TD></TR></TABLE>
I'm referring to the one on the front of the transmission and on the front left side of the block (on the a/c compressor bracket)
Old Jul 12, 2005 | 05:26 PM
SneezR's Avatar
Default Re: (Boondock Saint)
Oh okay. Thanks
Old Jul 12, 2005 | 05:51 PM
Rod.'s Avatar
pm'd you sneezr
Old Jul 12, 2005 | 07:09 PM
lucidvtec's Avatar
does that window weld fill on the motor mounts really work...does it last..cause damge..what's the skinny???
Old Jul 13, 2005 | 05:39 AM
SneezR's Avatar
Default Re: (lucidvtec)
https://honda-tech.com/zerothread?id=1283237
I just made the purchase on the es bushings and I decided to use 3m window weld on the 2 side mounts up top.
whoneedzvtec
Nov 21, 2007 04:13 AM
Boner_Ben
Welding / Fabrication
Sep 29, 2007 02:04 PM
integrawow
Suspension & Brakes
Nov 10, 2006 09:48 PM
strictly.business
May 2, 2006 11:40 PM
ragejed
May 18, 2002 06:56 PM
