LS Turbo problems
Old Jul 12, 2005 | 02:34 PM
Blue98Ex's Avatar
Default LS Turbo problems
Ok the motor is an LS with pistons & rods. Car has been fully street tuned and dyno tuned. Car runs great the majority of the time but then all of a sudden it starts like stuttering when its just cruising, it feels like ur taping the brakes actually. And usually when this starts the car also starts to just stall everytime u goto stop it. Like when were just driving and try to stop at a redlight and put the car in neutral sometimes it just cuts off. Ne ideas whats wrong with it?
Old Jul 12, 2005 | 03:52 PM
Blue98Ex's Avatar
Default Re: LS Turbo problems (Blue98Ex)
BTW the car is turbo and put down 400+ whp on the dyno... Its been running flawless for over a year until just recently. The check engine light also pops in randomly, even after the new o2 sensor install.
Old Jul 12, 2005 | 03:55 PM
Dragline's Avatar
What code is ?
Old Jul 12, 2005 | 04:00 PM
Blue98Ex's Avatar
Default Re: LS Turbo problems (dragline)
I dont know what code it is... The light comes on for a few minutes and then just goes right back off, it never stays for long and it just happens randomly. Sometimes we drive it and nuthing is wrong at all and it drives fine. The car does the stuttering and stalling even when the check engine light isnt on though.
Old Jul 12, 2005 | 05:09 PM
Blue98Ex's Avatar
Bump for some help
Old Jul 12, 2005 | 05:31 PM
Dragline's Avatar
I would say check for A loose connection some where or maybe A loose ground.
Old Jul 12, 2005 | 07:28 PM
hybridsol's Avatar
Sounds like an AFC hack with a bad map sensor wire... What fuel/engine management are you using?
Old Jul 12, 2005 | 08:45 PM
Blue98Ex's Avatar
Default Re: LS Turbo problems (hybridsol)
Its Hondata tuned by Mase and until about a month ago it hasnt had this problem.
Old Jul 12, 2005 | 08:56 PM
Cloner's Avatar
You have an intermitent sensor problem most likely.
Old Jul 12, 2005 | 09:50 PM
Blue98Ex's Avatar
Default Re: LS Turbo problems (Cloner)
How do I fix this?
Old Jul 13, 2005 | 09:37 AM
Blue98Ex's Avatar
Bumpity bump
Old Jul 13, 2005 | 07:49 PM
Blue98Ex's Avatar
No one else have a similar problem before?!?
OneTyteEK9
Mar 9, 2006 11:43 AM
kydragger
Aug 24, 2005 04:53 PM
Blue98Ex
Jul 18, 2005 07:07 AM
Patron
Mar 23, 2004 04:17 AM
