Confused, can this be done?
Old Jul 12, 2005 | 09:53 AM
LSEGHATCH's Avatar
Default Confused, can this be done?
How can I get 3 different stages of boost? I was thinking 7psi for daily, 15psi, 25-30 (not sure yet) so that I can still drive my car on the streets and have a little fun but not go overboard.
Also how would tuning be accomplished, wouldn't I need three different settings for my A/F and timing?
Old Jul 12, 2005 | 09:57 AM
FOrSfEd's Avatar
Default Re: Confused, can this be done? (LSEGHATCH)
I believe turbo xs just came out with a 3 stage boost controller though honestly I don't know why you would need anything bigger than a two stage. One for daily and one for racing.
Old Jul 12, 2005 | 10:03 AM
mike1114's Avatar
Default Re: Confused, can this be done? (FOrSfEd)
traction control....less boost in lower gears would help with tire spin
Old Jul 12, 2005 | 10:05 AM
LSEGHATCH's Avatar
Default Re: Confused, can this be done? (mike1114)
True, I guess I could just go w/ 12-15 for daily and 20-30 for race. That's probably what I'll do then... But how does that work for tuning. The needs for 12-15 are a lot less than 25-30, the risk of detonating is much higher along w/ other factors.
Old Jul 12, 2005 | 11:00 AM
EJ1 wilcox's Avatar
You can tune both pressure levels on the same map... that part is easy...
Then just use a boost controller to control the different levels of boost.
Old Jul 12, 2005 | 02:05 PM
Si Shane's Avatar
Default Re: Confused, can this be done? (EJ1 wilcox)
matt k
Nov 17, 2007 06:08 PM
screaminvtec
May 23, 2007 10:13 PM
HYREV2NR
Aug 28, 2006 08:14 PM
SleepinTeg
Sep 27, 2005 01:37 PM
tygsr
Jun 19, 2002 01:27 PM
