b16 supercharger help
Old Jul 15, 2005 | 03:01 AM
jdmeg9's Avatar
Default b16 supercharger help
so far i have two problems....... my b16 is a second gen and i have a 00 si supercharger. the coolant line that attaches to the bottom of my throttlebody goes into my intake manifold next to my heater hose. on the si it doesn't it goes somewhere around the water neck for the lower radiator hose. i am not sure but this looks like it could be a problem. i figured since this said it would fit a del sol vtec too that it would be similar to my setup. second my map sensor controller has a spacer that goes in the map sensor that puts a vacuum line in there. moss motors will not give me a part number for it does anyone know where i can get something like this?
Old Jul 15, 2005 | 03:39 AM
sicky's Avatar
grammer nawzi
Default Re: b16 supercharger help (jdmeg9)
Forced Induction sectiom might yield more help. . .
Old Jul 15, 2005 | 05:29 AM
wilsel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">second my map sensor controller has a spacer that goes in the map sensor that puts a vacuum line in there. moss motors will not give me a part number for it does anyone know where i can get something like this?</TD></TR></TABLE>
You really don't need it. I found out after I located one that you can unscrew the map sensor, and attach the vacumn line to the bottom nipple on it. You just need to put something over the hole on the throttle body where it used to be so you don't have a vacumn leak. If you want it to look better you can get this:
http://www.overboost.com/obs/p..._name=
Old Jul 15, 2005 | 01:08 PM
jdmeg9's Avatar
Default Re: b16 supercharger help (wilsel)
so i could use a dx map sensor on it?
crxsleeper210
Oct 10, 2007 09:28 AM
civicflow
16
Jun 7, 2007 10:50 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
spidermancivic
Aug 25, 2005 09:45 AM
kangjin
Dec 8, 2001 10:49 PM
