TPS wiring
Old Jul 15, 2005 | 07:24 AM
Crasian's Avatar
Default TPS wiring
hey people, my c ar is running horribly rite now, it will not go above 2500 rpm and its been doing this ever since3 i did the swap, anyways i was looking at my TPS and it has 3 wires going to it, i noticed the yellow and white wire does not end up going to my ecu. Where the engine harness wires plug into on the pass side by the right front strut there is where the yellow and white wire goes, but there isnt another wire that it plugs into, leading it to the ecu. Could this be my problem? Because i am not getting a TPS CEL code
Old Jul 15, 2005 | 07:25 AM
Crasian's Avatar
oops, posted this in the wrong section, could a mod please move this to 92-00 civics section cuz teh car is a 93 civic dx
Old Jul 15, 2005 | 08:00 AM
Flamenco-T's Avatar
Default Re: (Crasian)
You may have the TPS and MAP plugs switch when you install it. Double check it again. It is easy to miss that, the plugs are the same and location is close enough
stan
ZombiePharoh
Dec 3, 2012 02:45 PM
DenzComp
29
Jul 5, 2007 06:26 PM
ZzZCivicZzZ
Aug 11, 2006 11:58 PM
RedRacerCivic
Feb 26, 2002 04:06 PM
