Uberdata on 98 EX (built motor)
Old Jul 13, 2005 | 10:37 AM
flood's Avatar
Default Uberdata on 98 EX (built motor)
Friend has a 98 ex (d16y8) and a built motor. He has been using the AFC hack to get by with untill a better solution could be had. I have talked him into using uberdata and need some info.
The car is OBDII and I understand you have to use a chipped OBDI board.
Would that be a P28 thats socketed?
Is there anything that will be a problem going from the stock ECU (OBDII) to a socketed OBDI? Anything that may be a problem or concern?
I know we will need a rom burner and thats ok. I will find the suggested one on the uberdata forums. I just am a bit in the dark about swapping out the ECU and what will/wont work once its been done.
Old Jul 13, 2005 | 10:43 AM
inspyral's Avatar
You just need an OBD-IIA>>OBD-I adapter harness.
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Uberdata on 98 EX (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">Friend has a 98 ex (d16y8) and a built motor. He has been using the AFC hack to get by with untill a better solution could be had. I have talked him into using uberdata and need some info.
I know we will need a rom burner and thats ok. I will find the suggested one on the uberdata forums. I just am a bit in the dark about swapping out the ECU and what will/wont work once its been done. </TD></TR></TABLE>
Don't let your friend touch his ECU.
Either read the Uberdata website or take the car to a professional tuner.
No sense risking a freshly built motor.
P.S. what's the motor setup, rods/pistons, headwork, etc...
Old Jul 13, 2005 | 11:51 AM
flood's Avatar
Default Re: Uberdata on 98 EX (boostincoupe)
Ported head, eagle pistons and rods (8.5:1), hybrid turbo (unknown), spearco intercooler, 255 fuel pump, adj fuel pressure reg, tuner toys 450cc inj, loud *** BOV, AEM cam gear, adj boost valve(gillis)
honestly I think this is something we can accomplish. I have just started reading into the uberdata forums. Why would you advise not to touch the ECU? I mean its running an AFCII hack now, an uberdata basemap to get it to a dyno or street tune with a wideband should be better right?
Old Jul 13, 2005 | 12:08 PM
Harassing Herbs's Avatar
ALL THE answers to your questions are already on line. try searching or reading the uberdata web site. you can find the answers to these questions but u feel you can accomplish the tuning part of your car. just about anything is better than the hack method on a turbo car
Old Jul 13, 2005 | 12:13 PM
flood's Avatar
Default Re: Uberdata on 98 EX (Harassing Herbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harassing Herbs &raquo;</TD></TR><TR><TD CLASS="quote">ALL THE answers to your questions are already on line. try searching or reading the uberdata web site. you can find the answers to these questions but u feel you can accomplish the tuning part of your car. just about anything is better than the hack method on a turbo car</TD></TR></TABLE>
I think you mean "I can't" find the answers to these questions right?
lets see usefulness of your post 0
Old Jul 13, 2005 | 12:50 PM
mtber's Avatar
https://honda-tech.com/zerothread?id=1242980
Old Jul 14, 2005 | 09:57 AM
flood's Avatar
Default Re: Uberdata on 98 EX (mtber)
So I ordred the OBDIIa&gt;OBDI adapater harness and working on getting the chipped ECU from MTBER.
Also I contacted a tuner off the pgmfi.org boards about tuning in Denver. So hopefully you will see some pics and 1/4mi times of another turboed Civic.
Old Jul 14, 2005 | 11:33 AM
Sivik's Avatar
quick question... you have a built motor, why only 450cc injectors? seems a bit small for a built motor.
Old Jul 14, 2005 | 01:24 PM
flood's Avatar
Default Re: (Sivik)
Its kind of a learning process, with the VAFC 450cc was as big as you could go and still be able to idle. Even with the 450s its too much to idle with, way rich even with -50. These are also saturated injectors and don't require the resistor.
EKMIKEY27
Dec 18, 2010 03:19 PM
GReddyTurboCoupe
Jun 12, 2005 07:05 PM
ITR1071
Feb 24, 2003 12:33 AM
