no spark.. need help !!!
Old Jul 14, 2005 | 02:14 PM
turboH22Aakkord's Avatar
Default no spark.. need help !!!
ok, i thought my distributor was fucked.... so i bought a new one... and ... nothing... i just put a new chipped p28 in it and im getting at code 22 vtec... i had someone chip it for me ... maybe they fucked it up... but i have no idea why this car wont spark now... i have checked all the grounds and everything seems ok.. i just need some advice.... thanks... (please help)
Old Jul 14, 2005 | 04:26 PM
PrettyLude's Avatar
was it doing this before you got the chipped ecu?
Old Jul 16, 2005 | 08:28 AM
Boosted Power's Avatar
It could be ECU. If not, then run through a quick simple spark diagnose.
Old Jul 16, 2005 | 09:52 AM
11SECEG's Avatar
Default Re: no spark.. need help !!! (turboH22Aakkord)
put another known good ecu and go from there!!!!
Old Jul 16, 2005 | 10:32 AM
YiNYaNg's Avatar
Cut the J1 wire jumper inside your ecu and it'll turn back to stock mode. See if beening stock solves your problem.
Old Jul 17, 2005 | 12:09 PM
Default Re: no spark.. need help !!! (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">Cut the J1 wire jumper inside your ecu and it'll turn back to stock mode. See if beening stock solves your problem.</TD></TR></TABLE>
thanks guys... i have tried a couple different ecu's and nothing... i thought it was the dizzy cause it was all rusted and **** but i replaced that and still nothing... there was something wierd though... where the charge pipe goes by my powersteering it was touching a metal clamp for the PS and when i would crank the car over it would spark at that point... so i checked all the grounds and now it doesnt do that anymore but still no spark....thanks guys.. more help is welcomed!
Old Jul 17, 2005 | 12:19 PM
1700anddroping's Avatar
try the main relay under the dash.....
harv
Old Jul 17, 2005 | 03:06 PM
mamaboy's Avatar
check the fuses. the short could have blown a fuse. check the relay. try another dizzy / module
Old Jul 18, 2005 | 05:54 AM
Default Re: no spark.. need help !!! (1700anddroping)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1700anddroping &raquo;</TD></TR><TR><TD CLASS="quote">try the main relay under the dash.....
harv</TD></TR></TABLE>
thats the last thing that i havent tried.. i relay think that is what it must be... is it hard to get to that relay? cause it is under the dash... how do i check it? like is there any way to check it with a multi meeter? thanks ....
Default Re: no spark.. need help !!! (mamaboy)
all the fuses are good... i check them... and the dizzy is brand spankin new... right out of the box... i dont have a spare kickin around... i wish i did... thanks...
Old Jul 18, 2005 | 07:22 AM
bump bump bump....
Old Jul 18, 2005 | 08:15 AM
t x3.... i need ya fellas
Old Jul 18, 2005 | 02:59 PM
you have to remove a sliver box and then you can see it.i'll tell you and old trick.
hit w/a screw driver a couple of times.sometimes you get lucky sometimes you don't....good luck.
harv
Old Jul 19, 2005 | 05:17 AM
kool man.. thanks... ill give it a try
onesickej1
Nov 5, 2009 07:04 AM
1990EFHATCH
Apr 8, 2008 10:09 AM
ICEMAN707
12
Jul 2, 2006 03:45 PM
s1ngle
Jul 30, 2004 04:48 AM
