turbo oil feed question / possible problem
ok today i started my turbo install and eveything went smoothly until i got the to oil feed and return. i unplugged and unskrewed the oil pressure sensor and inserted the little brass T and what not but it only skrewed in maybe 1 1/2 turns but it is tight and i dont want to tighten it more and crack the block, plus it is in an odd spot. so my question is... will the pressure build so high that it will loosten that fitting and eventually come off? od should i be good? it is really snug on there but was not in very far. thanks a bunch in advanced!
-nick-
-nick-
i wouldn't mount the T on the block get a 24" piece of SS and put the T on the firewall alot safer and you can add extra T's for other senders and stuff..u don't want that T breakin off inside ur block
Re: (Rubixcu7)
It wont screw in enough because the block is BSPT and your fitting is NPT. I had the same problem at first too. You shouldnt have a problem with just a T fitting coming off of it, just get a BSPT fitting, that is the most important thing.
Re: (TurboCoop)
Coop is exactly correct. We offer a perfect solution for this problem. Check them out here - http://tunertoys.zoovy.com/product/OTODK It's an oil fitting with the correct BSPT and NPT threads, to correctly install an oil feed line on any Asian import vehicle.
Re: (TunerToys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerToys »</TD></TR><TR><TD CLASS="quote">Coop is exactly correct. We offer a perfect solution for this problem. Check them out here - http://tunertoys.zoovy.com/product/OTODK It's an oil fitting with the correct BSPT and NPT threads, to correctly install an oil feed line on any Asian import vehicle.
You know what I used an npt fitting and it went in fine. Screwed in by hand for like 4-5 complete revolutions then I just tightened it down, no leak. But I did use a swagelock (dont know if any of you are familiar with it) fitting and those things kick ***. I'll post a pic up of my oil feed line, its all ss swagelock tubing courtesy of my work. I hope I dont have problems down the road, but It has been good so far.........*fingers crossed*
Re: (KeyserSoze)
I've never tried it, but I would imagine an npt fitting could be "installed" in there just once. I wouldn't trust it to ever come out and go back in though. lol
It'd be a one time deal.
Re: (TunerToys)
Tuner toys, this may sound funny, but i bought one of these from you awhile back ago. It also broke like the 3 other brasses i had. It held longer than my brass ones. Maybe i had a bad one?
Re: (stealthmode62)
got a GE oil sandwich plate after that. When things happens, you dont think of it till later. I bought it on ebay from tuner toys. Probally send him an email about it.
Re: turbo oil feed question / possible problem (B18EG6)
Or spend $4 on a 1/8 NPT tap and just use an NPT fittings. I don't get why people go through so much hassle when youy could just run NPT to begin with.
Re: (95boostedteg)
- 95BoostedTeg
You had one break? We would have replaced it for free, no questions asked!
What did you have connected to it? (This one of the first reports I have had about breakage on these, so I am eager to see what went wrong.)
- Stealthmode
You are correct, installing an NPT into a BSPT will work, just once. The difference between the threads is just enough to slightly disturb the threads in the aluminum block. It's kind of like getting your chick "just a little pregnant". There is no going back.
- nfn15037
The tap idea might work, but there may not be enough material to effectively reshape the threads to NPT. The potential for creating a bigger mess (especially for a novice) is pretty large. Aluminum is unforgiving in the first place, and does not lend itself well to reshaping. Getting the correct fitting in the first place, may save a lot of people a huge headache, leaving the more complicated tasks to the more experienced folks like yourself.
Craig
- Stealthmode
- nfn15037
Craig
dunkd
02-15-2004 01:50 PM
