can i use two wastegates to avoid boost creep
Old Jul 12, 2005 | 11:58 AM
h kid's Avatar
Default can i use two wastegates to avoid boost creep
well im almost done with my set up and im going to be running a internaly watgated t3 turbo on my d15 j spec, but im scared of geting boost creep from the stock waste gate, and i recently found a cheap 40 mm tial knock of that i want to use, but since i dont trust either one i want to use both so if one fails the other will back it up and i wont go boom couse i wanted to go cheap. My question to you is can it be done, and no dont tell me to buy the real thing im only gonna bost around 7-8 psi and i dont have the money to buy the right thing.
Old Jul 12, 2005 | 12:21 PM
h kid's Avatar
Default Re: can i use two wastegates to avoid boost creep (h kid)
anybody know, i have never heard of any body doing this but i think it will prevent me from boost creeping
Old Jul 12, 2005 | 12:25 PM
NuclearB18B's Avatar
you could always try and find out...
Old Jul 12, 2005 | 12:30 PM
h kid's Avatar
Default Re: can i use two wastegates to avoid boost creep (NuclearB18B)
that's what im probably going to do,since im thinking no one has ever done this and the knock off waste gate is very affordable so ill see what happens. i just need to start installing my stuff, I've had this set up in my room for around 4 months know and im too lazy to install this stuff because of the welding an taping of things.
Old Jul 12, 2005 | 12:31 PM
B6tPoweredMx3's Avatar
You could always get a seperate dump for the internal wastegate.
Old Jul 12, 2005 | 12:33 PM
Muckman's Avatar
Moderator in Chief
Jordo used two wastegates on his setup to avoid boost creep.
Old Jul 12, 2005 | 12:47 PM
h kid's Avatar
Default Re: can i use two wastegates to avoid boost creep (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Jordo used two wastegates on his setup to avoid boost creep.</TD></TR></TABLE> theirs my answer then it can be done and has been done and im guessing it works so ill be doing this.
Old Jul 12, 2005 | 02:07 PM
EJ1 wilcox's Avatar
I've seen two external wastegates used in pretty extreeme appliacations, but never an internal and external used together....
Why are you so worried about boost creep? It's not that big of a deal. You are not going to see much creep if any at only 7-8 psi, I wouldn't even worry about it.
Old Jul 12, 2005 | 02:08 PM
dustin's Avatar
why not use the internal gate, and fix the creep?
Old Jul 12, 2005 | 02:29 PM
h kid's Avatar
Default Re: can i use two wastegates to avoid boost creep (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">why not use the internal gate, and fix the creep?</TD></TR></TABLE>
well i havent installed the turbo yet, and it isnt a new turbo its a hmt set up so im just scared the wastegate might not work and the first time i boost it will blow, its just for a safety precoution, i dont want to regret it.
Old Jul 12, 2005 | 02:35 PM
Johnyquest's Avatar
There is no reason why you couldn't.
Old Jul 12, 2005 | 02:38 PM
Cloner's Avatar
QUOTE=h kid]well im almost done with my set up and im going to be running a internaly watgated t3 turbo on my d15 j spec, but im scared of geting boost creep from the stock waste gate, and i recently found a cheap 40 mm tial knock of that i want to use, but since i dont trust either one i want to use both so if one fails the other will back it up and i wont go boom couse i wanted to go cheap. My question to you is can it be done, and no dont tell me to buy the real thing im only gonna bost around 7-8 psi and i dont have the money to buy the right thing. [/QUOTE]
I think they get stuck open more than they get stuck closed.[
Old Jul 12, 2005 | 02:50 PM
urbansi's Avatar
Default Re: can i use two wastegates to avoid boost creep (B6tPoweredMx3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tPoweredMx3 &raquo;</TD></TR><TR><TD CLASS="quote">You could always get a seperate dump for the internal wastegate.</TD></TR></TABLE>
Not to thread jack but......
i have never heard/seen of this, explain/show..........
Old Jul 12, 2005 | 02:52 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h kid &raquo;</TD></TR><TR><TD CLASS="quote">well i havent installed the turbo yet, and it isnt a new turbo its a hmt set up so im just scared the wastegate might not work and the first time i boost it will blow, its just for a safety precoution, i dont want to regret it.</TD></TR></TABLE>
Haha... dude, don't waste your money trying to solve problems that aren't even problems yet.
Why are you so worried about the wastegate not working? Most stock turbo cars use internal gates and have no problems. I don't know why you are so concerned about your wastegate failing when you don't even have it on the car yet.
Besides, if you do overboost, just let off the gas. My stock d has spiked up to 14psi when I was working on my boost controller and it didn't do any harm, as long as you let off the gas when your boost gauge shoots up you should be fine.
wantboost's Avatar
Who is Mr Robot?
you worry too damn much, the internal will be fine for those boost levels. just smooth out the wg flapper port, they get stuck open more than they get stuck closed
Old Jul 12, 2005 | 02:56 PM
h kid's Avatar
Default Re: can i use two wastegates to avoid boost creep (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
Besides, if you do overboost, just let off the gas. My stock d has spiked up to 14psi when I was working on my boost controller and it didn't do any harm, as long as you let off the gas when your boost gauge shoots up you should be fine. </TD></TR></TABLE> ya i guess your right but im trying to make everything run reliable and i dont want to come crying to you guys when i blew up couse of something stupid so its better to know and learn as musch as i can from experianced ppl before I get aon it.
Old Jul 12, 2005 | 02:57 PM
pimpintyperintegra's Avatar
i know you can run two external wastegates, but i have never seen one internal and one external used before
in your case, you just need one or the other, though
wantboost's Avatar
Who is Mr Robot?
Default Re: can i use two wastegates to avoid boost creep (pimpintyperintegra)
yup. ^ i wish your pt71 was bb
Old Jul 12, 2005 | 03:31 PM
Default Re: can i use two wastegates to avoid boost creep (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">
i have never heard/seen of this, explain/show..........</TD></TR></TABLE>
I probably should have been more decisive with my words but what i meant was to have a seperate tube for the wastegate .
Old Jul 12, 2005 | 03:58 PM
urbansi's Avatar
seperate tube for and internal???
Old Jul 15, 2005 | 12:40 PM
yee SERIOUS's Avatar
you'll be fine with just the internal one. just use that one.
ryanangelo212
Oct 26, 2010 05:46 PM
Rob03Pro5
Aug 29, 2008 06:09 PM
MassScene
Feb 26, 2007 08:03 PM
reignofchaos
Sep 24, 2003 06:56 PM
Andrew 825SM
21
Dec 9, 2002 04:26 PM
