Place to Buy Oil Catch Can + PVC Breather
Im looking for something like this
where is a good place to buy them and spend under 100 bucks shipped?
i want something semi sleeper living in CA, i might just paint it black.
something like this
both are custom, any place make them like this?
summit has some, but they are a bit to big, my bay is already clutted, looking for somethin not to big.
something like this
Re: Place to Buy Oil Catch Can + PVC Breather (Quad-Damage)
I'd get on with a -10 or -12an inlet and a breather filter that has at least a 1-3/8 outlet diameter . Those your showing prolly don't "breath" very well . And add a fitting to the front side of the valve cover for the pickup.
Re: (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage »</TD></TR><TR><TD CLASS="quote">they only make b series</TD></TR></TABLE>
A catch can is universal, you just have to hook up a line from your block, valve cover or PCV black box to the catch can inlet. How are you planning on hooking up the can to your motor?
EDIT the Endyn kit is made specifically for a B series motor cause I think the kit has two Honda fittings that can be screwed into the back of the block. And there is also a freeze plug that gets placed in the stock PCV hole. But other then that the tank itself is universal. Jut have to find the right AN size fitting or whatever and conect the hoses.
RTW DC2R
03-13-2007 09:55 AM
