hondata install????
Old Jul 12, 2005 | 09:07 PM
d!zZy's Avatar
Default hondata install????
i just got my hondata from importparts today and there is a chip in the hondata box. does this chip go in the ecu? and do i have to remove my vafc? i already installed it an the red led stays on and the car runs hella rich and like pure crap.
thanks
i have already done a search, and looked on the hondata website and it hasnt helped at all.. according to hondata i put everything in right, but it still runs crappy.
oh ya the cel stays on too.
Old Jul 12, 2005 | 09:13 PM
97turbols's Avatar
Default Re: hondata install???? (d!zZy)
tuning is your friend
Old Jul 12, 2005 | 09:54 PM
d!zZy's Avatar
Default Re: hondata install???? (97turbols)
it has a base map.. i need help with this!
Old Jul 12, 2005 | 10:43 PM
lucidvtec's Avatar
take out ur vafc 1st...did you install the big chip..little chip and resitorors...cut some jumper...what ecu you runnin....base maps shouldn't be to bad
Old Jul 12, 2005 | 10:49 PM
inspyral's Avatar
My basemap ran like utter garbage until I got tuned.
Old Jul 13, 2005 | 11:18 AM
d!zZy's Avatar
Default Re: (inspyral)
everything was done to the ecu except there was a big chip an i put that in.. going to uninstall the vafc right now.. ecu is a jdm p30
Old Jul 13, 2005 | 11:19 AM
dustin's Avatar
base map -> car runs like poo
tuned -> car runs better than poo
Old Jul 13, 2005 | 11:25 AM
97turbols's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d!zZy &raquo;</TD></TR><TR><TD CLASS="quote">it has a base map.. i need help with this! </TD></TR></TABLE>
You solved your own problem. Base maps are only intended to get the car running.
Old Jul 13, 2005 | 12:18 PM
d!zZy's Avatar
ok vafc uninstalled and now car will not hold an idle.. this is kinda frustrating
Old Jul 13, 2005 | 12:27 PM
dustin's Avatar
did you connect OEM map sensor wire back together at the ecu? hehe
Old Jul 13, 2005 | 12:31 PM
turbosi03's Avatar
Default Re: hondata install???? (dustin)
um, he said the big chip isn't installed. isn't that where the map would be stored? he must be running stock ECU with the hack still connected...
thats why it doesnt run with the hack taken out
Old Jul 13, 2005 | 12:32 PM
dustin's Avatar
wait um, you didn't put the chip in the ecu? contrary to popular belief, you're not supposed to eat this chip.. it actually has the fuel maps/timing maps/code that runs your car.
Old Jul 13, 2005 | 12:36 PM
turbosi03's Avatar
haha! beat you to it... must be the redbull
Old Jul 13, 2005 | 12:40 PM
d!zZy's Avatar
Default Re: hondata install???? (turbosi03)
ok im an idiot.. the chip is in.. i didnt put in the jumper in the j1 slot.. so im lookin at my ecu right now and i see j2 and j3 but no j1..
Old Jul 13, 2005 | 12:42 PM
dustin's Avatar
right above the chip area on the right... says J1
Old Jul 13, 2005 | 12:52 PM
d!zZy's Avatar
is that a usdm ecu? cause im using a jdm ecu if that makes a diff.. and i still dont see it!
Old Jul 13, 2005 | 01:16 PM
d!zZy's Avatar
ive been staring at this dman ecu for a half an hour.. anyone got any pics of were j1 is?
Old Jul 13, 2005 | 01:41 PM
dustin's Avatar
that's a usdm p72? are you using like a square jdm ecu?
do you see J1 in my pic?
Old Jul 13, 2005 | 01:42 PM
d!zZy's Avatar
i dont know what i just did but now its idleing fine.. im using a jdm p30 and the j1 is on the underside of the ecu.. and it already has the jumper on it.. i pulled the chip out and put it back in now it works fine.. thanks for your help!
Old Jul 13, 2005 | 01:44 PM
dustin's Avatar
Old Jul 13, 2005 | 01:57 PM
d!zZy's Avatar
ya that looks nothing like my ecu..
Old Jul 13, 2005 | 02:03 PM
d!zZy's Avatar
the red led stays on.. good or bad?
Old Jul 13, 2005 | 02:25 PM
Spunkster's Avatar
Should be on. The insturctions on the CD or from the Hondata website in the Downloads section should tell you exactly how to socket a JDM ECU.
Old Jul 13, 2005 | 02:28 PM
turbosi03's Avatar
solid red = good
blinking red = bad
Old Jul 13, 2005 | 02:47 PM
dustin's Avatar
Default Re: hondata install???? (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">Should be on. The insturctions on the CD or from the Hondata website in the Downloads section should tell you exactly how to socket a JDM ECU.</TD></TR></TABLE>
w00t hondata.com doesn't respond to pings
PING hondata.com (64.128.10.25) 56(84) bytes of data.
--- hondata.com ping statistics ---
41 packets transmitted, 0 received, 100% packet loss, time 40175ms
hondata.net works (the right frame?)
