weird problems started today, whats causing them?
Old Jul 12, 2005 | 12:11 AM
budget's Avatar
Default weird problems started today, whats causing them?
some of you may have seen my thread about me thinking about my screen getting sucked in, just thinking if they are related to my problems.
1-smokes a lil more on start up
2-can smell oil/gas more than usual
3-while engaging the clutch to stop, idle drops really low, almost stalling out
Old Jul 12, 2005 | 07:19 AM
budget's Avatar
bump 4 help
Old Jul 12, 2005 | 10:30 AM
Rod.'s Avatar
Default Re: (suxway)
check for leaks
maybe your rings are going
do you have a light weight flywheel
Old Jul 12, 2005 | 09:31 PM
budget's Avatar
Default Re: (Rod.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. &raquo;</TD></TR><TR><TD CLASS="quote">check for leaks
do you have a light weight flywheel</TD></TR></TABLE>
doesnt seem like any leaks
rings? hopefully not
yeah a lighter flywheel than stock, act streetlite 12lbs or so
Old Jul 13, 2005 | 06:12 AM
Hyaboosta's Avatar
Do a leakdown and compression test. if it checks out then it may be the seals in the turbo. does it smoke from the exhaust or from the engine bay?
Old Jul 13, 2005 | 08:57 PM
budget's Avatar
Default Re: (Hyaboosta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta &raquo;</TD></TR><TR><TD CLASS="quote">Do a leakdown and compression test. if it checks out then it may be the seals in the turbo. does it smoke from the exhaust or from the engine bay?</TD></TR></TABLE>
exhaust
Old Jul 15, 2005 | 06:28 PM
budget's Avatar
Default Re: weird problems started today, whats causing them? (suxway)
LS94tegra
May 23, 2008 07:41 PM
funtak
Oct 25, 2007 08:47 PM
latindc2
May 26, 2007 08:30 AM
cbmprelude
Jun 16, 2006 12:07 PM
zseeanz
26
Jan 16, 2004 12:10 AM
