Problems with Greddy profec b (Original)
Here are the problems,
1: The solenoid seems to be continuously active, there is a ticking sound from the solenoid box.(even when the car is off)
2: It completely drains my battery.
3: With the controller OFF, I boost until my boost cut-off, which is 10psi. I only have a 7.43psi spring in my Tial 38mm.
So there are the symptoms, And I need a diagnostic please.
Any help would be great.
Thanks
Thanks
does the unit power off when you shut the car off?
Check n c if you have it wired to a 12v constant instead of 12v ignition power source.. While your at it you might aswell look at the grounds.
