nitruos question
Old Jul 14, 2005 | 03:14 PM
ef8 h0!'s Avatar
Default nitruos question
I know im probably going to get flamed for this so.. ::flame suit on:: anyways..
Right now, I have a pretty much stock b16 in a CRX. I was thinking of a wet nitrous setup but I would like to still be somewhat safe. So my question is, would injectors be a good idea for just a 50 shot even with a wet system and a decent tune? Or does the wet shot kinda make up for stock injectors? Keep in mind it would just be a wet shot right before the throttle body. Thanks in advance.
Old Jul 14, 2005 | 03:33 PM
ef8 h0!'s Avatar
Default Re: nitruos question (ef8 h0!)
No one?!
Old Jul 14, 2005 | 03:43 PM
ef8 h0!'s Avatar
someone has to know!
Old Jul 14, 2005 | 03:45 PM
MooreBoost's Avatar
Stock injectors are perfectly fine.
Old Jul 14, 2005 | 03:54 PM
ef8 h0!'s Avatar
Default Re: nitruos question (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Stock injectors are perfectly fine.</TD></TR></TABLE>
Thanks! now as for the tune should i just run a little more fuel and retard timing a little? advance spark? but then it will run rich without shooting. so im kinda stumped on the tuning.
Old Jul 14, 2005 | 04:01 PM
tegturbo's Avatar
retard the timing a little
Old Jul 14, 2005 | 04:10 PM
ef8 h0!'s Avatar
Default Re: nitruos question (1.7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.7turbo &raquo;</TD></TR><TR><TD CLASS="quote">retard the timing a little</TD></TR></TABLE>
thats all? no extra fuel? no extra spark?
Old Jul 14, 2005 | 04:23 PM
MooreBoost's Avatar
Run colder plugs and retard the timing slightly if you wish, however I don't think nitrous companies require it with just a 50 shot.
Your car will not run rich off the bottle because you aren't increasing fuel flow all the time. And if you do not retard the timing, then it wont be any slower at all. But better safe than sorry.
Old Jul 14, 2005 | 06:05 PM
Phase Change Racing's Avatar
Retard the timing 2 degrees, your stock plugs will be just fine but if you change plugs in the future go a couple heat ranges colder (because you won't stick with just a 50 shot for long hehe).
Old Jul 14, 2005 | 06:42 PM
ef8 h0!'s Avatar
Default Re: nitruos question (Phase Change Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase Change Racing &raquo;</TD></TR><TR><TD CLASS="quote">Retard the timing 2 degrees, your stock plugs will be just fine but if you change plugs in the future go a couple heat ranges colder (because you won't stick with just a 50 shot for long hehe).</TD></TR></TABLE>
so i noticed that u have a website. what kind of deal can you give me? come on another honda-tech-ian.
Old Jul 14, 2005 | 07:22 PM
I'll PM ya some info.
hbkxtbone
May 3, 2007 09:10 AM
Consistent1
Jun 19, 2005 08:06 PM
95accordh22a
Mar 2, 2005 05:50 AM
NathanMorris
Dec 9, 2004 11:57 AM
sharkey65a
Jan 21, 2003 02:38 PM
