Anyone running without a motor mount???
Old Jul 12, 2005 | 08:06 AM
Rod.'s Avatar
Default Anyone running without a motor mount???
I was getting ready to put one the torque mounts on underneath the car that bolts where the a/c is. I just notice that my turbo is in the way and I cant put the bracket on to bolt the mount on. Am I looking for trouble down the road??
Old Jul 12, 2005 | 08:07 AM
SOHC_MShue's Avatar
Default Re: Anyone running without a motor mount??? (Rod.)
I did this once and ended up with a dent in my hood
Old Jul 12, 2005 | 08:09 AM
Rod.'s Avatar
Default Re: Anyone running without a motor mount??? (SOHC_MShue)
what can I do????
Dunc's Avatar
BCICAN
....the mounts were put there by the honda engineers for a reason.
Old Jul 12, 2005 | 08:10 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. &raquo;</TD></TR><TR><TD CLASS="quote">what can I do????</TD></TR></TABLE>
"anything will fit with a little more force"..........is there no possible way to get the mount in there??
Old Jul 12, 2005 | 08:15 AM
SOHC_MShue's Avatar
Default Re: Anyone running without a motor mount??? (Dunc)
Try grinding part of the mount down if you have to. It will still be fine with 3 bolts instead of 4.
Old Jul 12, 2005 | 08:23 AM
Rod.'s Avatar
no way to get it in there. I will try to cut the corner off after work. Hopefully that will work
Old Jul 12, 2005 | 08:26 AM
sean's Avatar
yeah i had to grind mine down to fit. i was running without that mount, then my driver side mount took a **** and the motor dropped and shifted. use the mount.
Old Jul 12, 2005 | 11:13 AM
TypeRobert's Avatar
Default Re: Anyone running without a motor mount??? (sean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">....the mounts were put there by the honda engineers for a reason.</TD></TR></TABLE>
true that do whatever it takes to put that mount in there besides its only you that it helps
Old Jul 12, 2005 | 11:23 AM
raceACCORDingly's Avatar
what do civics and integs with h22's do?
with boosted accords its common to see guys running w/o the front mount but with filled/solid rear and side mounts.
numotive
Mar 12, 2007 09:42 PM
Project_EK
Jun 2, 2006 07:06 AM
Young Deezy Son
May 13, 2006 08:35 AM
94gsrhatch
Nov 20, 2004 05:35 PM
trbob16a
Sep 13, 2002 02:23 PM
