code 20 , no vtec
Old Jul 16, 2005 | 07:22 AM
Turbo_Mike's Avatar
Default code 20 , no vtec
Just got my car running with a chipped p28 using uberdata. When i first started it i had a code 20 (Eld). Then my friend disabled it in a new chip and it went away.
Only problem that i reallly noticed before ( besides the car feeling kinda slow) is no vtec. Could the vtec have anything to do with disabling the eld? We set the vtec at 4899 ....
Old Jul 16, 2005 | 09:57 AM
Turbo_Mike's Avatar
Default Re: code 20 , no vtec (MIKE JONES)
also my idle tends to get stuck up around 1.5-2k rpms. Could this be a timing isssue?
I'm gonna triple check for vacuum leaks, but i think its all good.
Old Jul 17, 2005 | 04:35 AM
Turbo_Mike's Avatar
help?
Old Jul 18, 2005 | 06:28 AM
Turbo_Mike's Avatar
STILL no vtec
Old Jul 18, 2005 | 08:12 AM
D@nnY's Avatar
is your speed sensor working? you better hope you have oil pressure
Old Jul 18, 2005 | 08:17 PM
Turbo_Mike's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">is your speed sensor working? you better hope you have oil pressure</TD></TR></TABLE>
I dont see why it wouldnt be, worked fine until i put this p28 in.
I dont have an oil pressure guage YET but it sure feels like its got something...
Old Jul 19, 2005 | 03:45 PM
Turbo_Mike's Avatar
Default Re: (MIKE JONES)
Is there anything else i have to do to run vtec with a p28? I'm using a conversion harness and ran the solenoid and pressure switch / ground wires.... ?
Old Jul 20, 2005 | 05:06 AM
Turbo_Mike's Avatar
Old Jul 21, 2005 | 07:48 PM
Turbo_Mike's Avatar
Just checked continuity between switch and teh ecu and its good. I made a few new connections but nothing else has changed in the last couple weeks, so i dont know what else to look at. Oil level is down to half between marks, but shoudl still be plenty enough.
Whats happening if the cams aren't engagin? Is the map still switching over to the high cam fuel map? ignition? My a/f dips down into mid to high 10s at 5k and sometimes up through 8k in full boost.
Driven
Sep 20, 2004 08:45 PM
2trix
Apr 2, 2004 08:15 PM
ltho1998
Aug 21, 2003 08:08 AM
Hondasaurs
May 9, 2003 08:51 PM
Houston Hatchback
Aug 24, 2002 06:03 PM
