oil pressure
Old Jul 13, 2005 | 03:22 PM
Midwest Auto Salon's Avatar
Default oil pressure
how common is it to shatter your oil pump? i have a brand new one installed in a built b18b and i lost all oil pressure and shut her down asap....its making a lil weird noise from the motor and i think it could be the oil pump....is there a possibility that i spun a bearing???
Old Jul 13, 2005 | 03:29 PM
dustin's Avatar
Default Re: oil pressure (Midwest Auto Salon)
Well if the oil pump shattered, that could cause the loss of pressure..
Do you know why you lost pressure?
Losing pressure with the engine at speed can definately spin bearings (or cause enough crank->bearing contact that they will spin soon)
Old Jul 13, 2005 | 03:31 PM
s2kdre's Avatar
only one way to find out, put a new one on and start it up
dustin's Avatar
Default Re: oil pressure (jdmhonda)
if only "put a new one on" was that easy with the motor in the car ... hehe.
Old Jul 13, 2005 | 03:35 PM
Default Re: oil pressure (dustin)
i was mashing on her and all of a sudden my oil pressure gauge went to 0 and the dash oil lamp lit up..i shut her down, found no leaks rolled to a lot and checked for leaks, found none, gauge still hooked up and even tried to reset the gauges and yet no oil pressure , strolled the car home about a miles away....if i let her idle it will make a funny lil ticking sort of a noise.....sad..only 1500 miles on this motor set up
Old Jul 13, 2005 | 03:37 PM
dustin's Avatar
pump could definately be toast... and the chances of a spun/damaged bearing are high. It still has no oil pressure, right? So when you let it idle, the dash light is on?? Definately don't start the car anymore until you get the problem fixed...
Old Jul 13, 2005 | 03:40 PM
yea when it starts the dash oil lamp is on...i havent started it since....why would it shatter? everything is brand new dammit...
Old Jul 13, 2005 | 05:30 PM
JDMisGOOD's Avatar
I have seen a few oil pump gears shatter... they just do...
Old Jul 13, 2005 | 06:05 PM
YiNYaNg's Avatar
I hate it when **** breaks when you least expect it.
Are you still going to the MN H-T meet?
MINNESOTA Honda-Tech meet - Sunday, July 17th!
Modified by H-T at 9:49 PM 7/13/2005
Old Jul 13, 2005 | 06:25 PM
wisjdmhonda's Avatar
that sucks. best of luck to you
Old Jul 13, 2005 | 07:57 PM
earl's Avatar
Don't forget to mention that UO pulley you were using rather than a harmonic balancer.
Old Jul 13, 2005 | 08:03 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: oil pressure (earl)
yea, an aluminum solid pulley will kill an oil pump rather quickly. what would you say the limits of the stock gear are? i have a fully built ls/vtec using a gt35r. my gaol is 450-500 on pump and 600 on c16. do you think i would be pushing the stock oil pump revving to say 9500? sorry for the semi0thread jack but it is on-topic
Old Jul 13, 2005 | 09:36 PM
JDMisGOOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to mention that UO pulley you were using rather than a harmonic balancer.</TD></TR></TABLE>
I Just looked at some pics he posted and you're right! That Shiny "lightweight" crank pulley is the cause.
Old Jul 13, 2005 | 09:55 PM
Default Re: oil pressure (JDMisGOOD)
yea that sux, stupid piece of shiet...lol oh well, tearing off the pan tomorrow moringin and hopefully no scarring....
probably wont make the meet, unless i get her running by then...
thanks for the info
Old Jul 13, 2005 | 10:08 PM
JDMisGOOD's Avatar
yeah man that sucks... you live and you learn...
Old Jul 13, 2005 | 10:18 PM
so lets say i did spin a bearing, what is the process to fixing this besides buying a new motor and starting over?
Old Jul 13, 2005 | 10:20 PM
earl's Avatar
Default Re: oil pressure (wantboost)
When all else is proper, I would definitely trust the stock pump and gears at 600.
Old Jul 13, 2005 | 10:21 PM
nvm i saw what you were responding to....bump for latenight info
Old Jul 13, 2005 | 11:43 PM
so after extensive search i came to the conclusion that the motor will probably be shot being that i drove it home with no oil pressure at like 20 mph for about 2 miles... LAME 1500 miles on this set up..
Old Jul 13, 2005 | 11:45 PM
inspyral's Avatar
Did you drop the pan and take a look yet? When my oil pump pickup wasn't torqued down enough, it came loose after about a day of driving and made this knocking sound, and my oil pressure began to drop. Luckilly I wasn't that far from home and limped it back into the garage. When I dropped the pan, I saw the pickup dangling, and one of the nuts had dropped completely off and was sitting in the pan.
Old Jul 13, 2005 | 11:48 PM
Default Re: (inspyral)
havent taken that off yet will do all that tomorrow...after mad reading i found out that driving it home was the worst thing i could do to it...drove it for about 2 miles no higher than 25 mph...coastiing in N when I could...probably going to have to junk this motor...sad i tell ya
Old Jul 14, 2005 | 08:39 AM
JDMisGOOD's Avatar
Default Re: (Midwest Auto Salon)
I'd put a new oil pump and fresh oil in it and see how she runs...
Old Jul 14, 2005 | 09:02 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (JDMisGOOD)
^ you ***, you changed your quote to something i never said... put it back
Old Jul 14, 2005 | 09:22 AM
Default Re: (wantboost)
tore it off, found a chunk ni the oil pickup or whatever it is, found really small shavings in the oil pan way in the bottom..i am using AMS Oil turbo oil and have a moroso road racing oil pan....so should i take off the rod rolts and check the bearings? overall there doesnt look like there is that many shavings in there...oil still looks fresh and clean.
Old Jul 14, 2005 | 09:47 AM
dustin's Avatar
take the rod caps off....
