AEM anti-lag - HELP
Old Jul 14, 2005 | 11:28 AM
cuin9sec
Guest
Posts: n/a
Default AEM anti-lag - HELP
just try to set-up my anti-lag feature and was wondering if some of you guys could post your settings. this option is ******* badazz but im only building like 3-4psi when i should be able to build 10+psi i would think. thanks in advance
Old Jul 14, 2005 | 01:40 PM
lucidvtec's Avatar
that is a bad as* feature...i heard it's really hard on the turbo thou..wish i could tell you how to set it up ....i think it works by dumpin extra fuel in the exhaust somehow...so the fuel burns in the manifold..makin the turbo spool faster
Old Jul 14, 2005 | 02:55 PM
D-tuned's Avatar
Default Re: (lucidvtec)
are you trying to set up anti-lag to build more boost off the line or full throttle shifts? what version are you on? I use the 2 step and I can i determine how much boost I want to build off the line. I can help you setup your 2 step to do the same
Old Jul 14, 2005 | 03:03 PM
cuin9sec
Guest
Posts: n/a
Default Re: (2000civicsi)
anti-lag is better. my 2-step is already setup...thanks though.
anyone have their anti-lag setup numbers thery want to post up from AEM?
Old Jul 14, 2005 | 05:17 PM
b00stedbyFastrax's Avatar
Default Re: (t67civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t67civic &raquo;</TD></TR><TR><TD CLASS="quote">anti-lag is better. my 2-step is already setup. </TD></TR></TABLE>
how are you achieving this with the 2-step.
Old Jul 14, 2005 | 06:25 PM
Jared's Avatar
Default Re: (b00stedbyFastrax)
In most setups I'm not even using the antilag. In the two step setup, set the retard rev limiter about 1500 before the ignition cut rev limiter and dont use the fuel cut rev limiter, the retarded timing will build tons of boost.
Example:
retard rev limit 5000
ignition cut limit 6500
fuel cut limit 12000
Old Jul 14, 2005 | 06:26 PM
Jared's Avatar
Default Re: (Jared)
btw, where in tn are you located?
Old Jul 14, 2005 | 07:36 PM
JDogg's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
Example:
fuel cut limit 12000</TD></TR></TABLE>
yep... works every time
we have the ability to build over 30psi on one of my customers supra's... gt42r
Old Jul 14, 2005 | 07:42 PM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t67civic &raquo;</TD></TR><TR><TD CLASS="quote">anti-lag is better. my 2-step is already setup...thanks though.
anyone have their anti-lag setup numbers thery want to post up from AEM? </TD></TR></TABLE>
might want to double check your settings if your building enough boost
Old Jul 14, 2005 | 08:14 PM
SpdFrk's Avatar
Anti-lag is a turbo killer. Your turbo wont last 5000k's with this option on. I had this option aswell and my turbo was destroyed after like 3500k's on it. But one thing i gotta admit its an awesome feature. You'll see flames shoot out your exhaust when ripping it on antilag.
Old Jul 14, 2005 | 09:55 PM
LeGeND4LiFe's Avatar
Default Re: (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">Anti-lag is a turbo killer. Your turbo wont last 5000k's with this option on. I had this option aswell and my turbo was destroyed after like 3500k's on it. But one thing i gotta admit its an awesome feature. You'll see flames shoot out your exhaust when ripping it on antilag.</TD></TR></TABLE>
I was really wanting to use this feature. Does it really kill good turbos quickly?
Old Jul 14, 2005 | 09:56 PM
JDogg's Avatar
Default Re: (LeGeND4LiFe)
no it dosnt kill your turbos that fast.. if you sit on the anti lag constantly it will, but for the occasional use at the track, it wont hurt anything
Old Jul 14, 2005 | 10:28 PM
SpdFrk's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">no it dosnt kill your turbos that fast.. if you sit on the anti lag constantly it will, but for the occasional use at the track, it wont hurt anything</TD></TR></TABLE>
This was for my street car that i only drove friday, sat and sundays not my race car that saw the track once awhile.
Old Jul 14, 2005 | 10:58 PM
JDogg's Avatar
what kind of turbo did you have? most of my customers run garrett gt turbos and have no problems after 10k+ miles
Old Jul 15, 2005 | 04:32 AM
Jared's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">what kind of turbo did you have? most of my customers run garrett gt turbos and have no problems after 10k+ miles</TD></TR></TABLE>
same here, the gts handle it well, but you will destroy a turbocharger with a standard 270deg thrust.
Old Jul 15, 2005 | 04:47 AM
B18CXr's Avatar
the anti-lag feature is far superior for instant, no load boost building than the rev limiter..
Old Jul 15, 2005 | 01:20 PM
cuin9sec
Guest
Posts: n/a
Default Re: (Jared)
same here, the gts handle it well, but you will destroy a turbocharger with a standard 270deg thrust.</TD></TR></TABLE>
i have a t3/t67 H.O. so i should be ok...lol.
Old Jul 15, 2005 | 01:38 PM
tgreaves's Avatar
What I do is keep lowering the rev-retard limit slowly until I build the amount of boost that I want.. Also raising the 2-step will allow you build boost faster..
Old Jul 15, 2005 | 01:59 PM
N20civicB18's Avatar
Default Re: AEM anti-lag - HELP (t67civic)
explain this anti lag, how does it work?
Old Jul 15, 2005 | 02:20 PM
cuin9sec
Guest
Posts: n/a
Default Re: AEM anti-lag - HELP (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">explain this anti lag, how does it work?</TD></TR></TABLE>
dumps a shitload of gas and retards timing...crazy **** huh?!?!
Old Jul 15, 2005 | 02:24 PM
do u keep the car floored like you would with a 2 step?
Old Jul 15, 2005 | 03:38 PM
SpdFrk's Avatar
Default Re: (JDogg)
This was on a t3/t04b from a drag kit. I replaced it with a sc61 but don't really want to try out the antilag on this turbo
Old Jul 15, 2005 | 06:02 PM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">This was on a t3/t04b from a drag kit. I replaced it with a sc61 but don't really want to try out the antilag on this turbo</TD></TR></TABLE>
it should be fine. several people use this option and it kicks *** if you ask me....when it works right...lol!
Old Jul 15, 2005 | 06:03 PM
JDogg's Avatar
you wont have any problems w/the sc61. we ran one of those for about 10k miles daily driven, raced every weekend.
if you use the aem boost control you can regulate the boost by vss, set the boost at 0mph for the ammount you want on the 2step
Old Jul 17, 2005 | 06:32 AM
Jared's Avatar
Default Re: (JDogg)
if you use the aem boost control you can regulate the boost by vss, set the boost at 0mph for the ammount you want on the 2step</TD></TR></TABLE>
This works very well, otherwise you have to set the retard rev limit and ign rev limit to dial in the amount of boost you need.
