DYNO- motor fine-timing wierd-horsepower not fine
DYNO- motor fine-timing weird-horsepower not fine
well i got dynoed for the 2nd time this time by Jason Hunt. He was able to bump it to 220 from 194hp. But he said something was wacky with my timing .he had to advance it alot on hondata and the distributor to make it run better. Heres my set-up.
98 prelude w/ 64k miles
greddy turbo kit & intercooler.
750cc rc injectors
walbro fuel pump
2.5 down pipe
2.5 cat
2.5 exhaust- (crush bend though )
hondata s100
manual boost controller set to 9psi
compression and leak down came back fine. any advice?
Modified by Drkaccrd at 3:45 PM 7/15/2005
750cc rc injectors
walbro fuel pump
2.5 down pipe
2.5 cat
hondata s100
Re: DYNO- motor fine-timing wierd-horsepower not fine (Drkaccrd)
he advanced it alot means nothing to us. Give us numbers. What is your base timing? What is the timing hondata?
Re: DYNO- motor fine-timing wierd-horsepower not fine (project dc2)
I think your exhuast might be an issue.... since its 2 1/2 crush bend that might be a problem.... you should think about upgrading it to like 3" from the header back or atleast making it mandrel bends just a thought
Edit: and get rid of your CAT!!! or take it out and run some ree bar threw it and get all the honey combe out that would free up some power right there
Re: DYNO- motor fine-timing wierd-horsepower not fine (BoostedEG6)
i was most afraid it would be that........... . then 3" exhaust (mandrel bent of course). if i keep the 2 1/2 down pipe, & cat you think should be fine?
Who is Mr Robot?
just go 3" all the way. the downpipe wont cost that much more if you have someone that can weld. you will see much better spool up times and top end numbers
Re: DYNO- motor fine-timing wierd-horsepower not fine (Dunc)
ok. total timing was retarded by 26 degrees. base timing retarded at 5. hondata retarded at 21 to equate to 26degrees overall. i think the restriction might be in the crush bent piping. i think the downpipe might have a bend in it also. what a mistake.
Re: DYNO- motor fine-timing weird-horsepower not fine (Drkaccrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd »</TD></TR><TR><TD CLASS="quote">.he had to advance it alot on hondata and the distributor to make it run better. </TD></TR></TABLE>
Your timing is off at the belt.....use a timing gun & fix it
Re: DYNO- motor fine-timing weird-horsepower not fine (SPR)
i imsunderstood what he said. the timing wasnt messed up. its my gay *** crush bent exhaust and one bend in the downpipe.
You could have a stock exhaust and still make more power. Something isnt right to be only maken 220 something at 9psi. I made 242.8 on a stock LS w/ 8.5psi.
Try also seeing if you timing belts havent skipped a tooth or anything. something is fishy...
Good Luck
Good Luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd »</TD></TR><TR><TD CLASS="quote">i imsunderstood what he said. the timing wasnt messed up. its my gay *** crush bent exhaust and one bend in the downpipe.</TD></TR></TABLE>
eh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">total timing was retarded by 26 degrees</TD></TR></TABLE>
hehe?
eh?
hehe?
hybridsol
08-13-2002 01:12 AM
