Aem 5 bar map DOA Please Help
Old Jul 13, 2005 | 07:01 AM
Turbocivic94's Avatar
Default Aem 5 bar map DOA Please Help
I bought a aem 5 bar map from Mid-West Supras and it was DOA. They dont have any phone #. I need this asap. Is anyone from AEM on this site help me get it replaced. Thanks in advance
Old Jul 13, 2005 | 07:55 AM
Flamenco-T's Avatar
Default Re: Aem 5 bar map DOA Please Help (Turbocivic94)
is your ECU not reading it ? what ecu are you running ?
stan
Old Jul 13, 2005 | 05:54 PM
Default Re: Aem 5 bar map DOA Please Help (Flamenco-T)
Its reading 57lbs of boost at idle. I'm using neptune.
Old Jul 14, 2005 | 07:54 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Its reading 57lbs of boost at idle. I'm using neptune. </TD></TR></TABLE>
Whos' your tuner ?
Old Jul 14, 2005 | 08:33 AM
turbo_civic_si's Avatar
double check your wiring. the input is seeing 5 volts. you should get about 1 volt on the signal.
Old Jul 14, 2005 | 05:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">
Whos' your tuner ?</TD></TR></TABLE>
Jeff Evans
Old Jul 14, 2005 | 05:43 PM
Default Re: Aem 5 bar map DOA Please Help (turbo_civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">double check your wiring. the input is seeing 5 volts. you should get about 1 volt on the signal.</TD></TR></TABLE>
It was reading 5 volts and signal was 4.85 volts. sensor is faulty and I sent it back to aem today. Thanks for everyones help
boostek9
Engine Management and Tuning
Sep 7, 2008 08:43 PM
vg7z
Sep 12, 2006 07:20 PM
crucian
Jun 24, 2004 09:20 AM
d_mina
Jun 11, 2004 12:36 PM
S2KP
Apr 20, 2004 03:36 PM
