compression ratio and boost
Old Jul 11, 2005 | 05:23 PM
usafa2010's Avatar
Default compression ratio and boost
I am building an engine and what i want to do is build an engine that can make power to 9000rpm. I was wanting to run compression at 10.75:1 with buddy club spec IV camshaft. I will also have eagle rods. I want to know will it be safe to run 10psi with that high of compression and rev out to where I want to get the power too. will I need to sleeve the block or anything like that. also for bearing tollerances is .0015 where is should be set to.
Thanks for any help
Old Jul 11, 2005 | 05:25 PM
Sketch_hs's Avatar
it's all in the tune and fuel.
btw search
Old Jul 11, 2005 | 05:34 PM
usafa2010's Avatar
Default Re: compression ratio and boost (usafa2010)
ya i ran a searh on it and did find some thing. I will just be using street gas either 91 or 93, its just 93 is so hard to find anymore
Old Jul 11, 2005 | 07:35 PM
SlowB16si's Avatar
With those rods I would get some pistons also. Maybe a little lower compression. That way with a good tune you could boost it pretty good.
Old Jul 11, 2005 | 07:41 PM
dustin's Avatar
If you want to run on pump fuel, get a good tune and you should be good to go.
Old Jul 11, 2005 | 08:24 PM
92SleepyHB's Avatar
Default Re: compression ratio and boost (dustin)
Currently I'm running JE 10:5:1cr pistons on a LS block with built GSR Head @12psi
Old Jul 12, 2005 | 05:52 PM
usafa2010's Avatar
Default Re: compression ratio and boost (92SleepyHB)
what kind of numbers are you making just curious also do u have the stock stoke and bore
Old Jul 12, 2005 | 07:18 PM
FOrSfEd's Avatar
people lately have been pulling off some crazy numbers with the stock bore.
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
GSRerrr
Apr 4, 2005 07:11 PM
PGT Driver
Apr 24, 2004 10:51 AM
7rrivera7
Oct 23, 2002 06:58 AM
lliew
Sep 13, 2001 05:26 AM
