oil feed/return length and size?
how long should my oil feed and return be, feeding off the oem oil pressure hole and returning into the highest point of oil pan? engine is a b18c, set up is peakboost a/c ramhorn with gt30r. also what feed line is recommended for a gt30r a -3 or -4? both with a 0.35 restrictor.
well, u need to use the kit, it takes pressure off the block and they are proper sized for our application. I would use a -3 w/o a restrictor, -4 with a restrictor.
http://www.xenocron.com/remote-oil-p...kit-p-329.html
the drain line usually is custome done because every turbo sits differently. But usually -10 with 2' of drain line will have you covered.
sampol999
Sep 3, 2006 01:09 PM
