think 300whp is obtainable?
Old Jul 19, 2010 | 04:47 PM
Mr. Chainsaw's Avatar
Default think 300whp is obtainable?
b16 stock bore, with JE 9:1 pistons
gsr cams, mild port b16 head
t3/t4 .50 A/R Compressor, .63A/R Turbine
255lph high volume fp
evo 560cc injectors
edlebrock victor x IM w/throttle body
open 2.5" dp.
short but wide generic ebay intercooler
ramhorn exhaust manifold
10psi. (stock map for now)
think it'll be enough for 300whp?
pic related (before IM and TB)
Old Jul 19, 2010 | 04:57 PM
azandford's Avatar
Default Re: think 300whp is obtainable?
im making the power in my sig with the same setup minus the victor x and have a cast mani at 11 psi
Old Jul 19, 2010 | 10:12 PM
AK94GSR's Avatar
i made 306 @ 10lbs on a stock b16a2 with arp headstuds/gsr cams/eclipse injectors.
u should be able get 300 with the right tune
Old Jul 20, 2010 | 04:55 AM
SAXON's Avatar
for 300whp stick with the stock intake manifold
Old Jul 20, 2010 | 11:47 AM
how would shorter runners supplying more air hurt performance?
Old Jul 20, 2010 | 12:04 PM
azandford's Avatar
i think what he was trying to say was that for theat power level the stock intake manifold would have sufficed but the victor x provides maximum torque between 7.5 and 9k
i wish i had a victor x...
Old Jul 20, 2010 | 05:32 PM
EsotericImage's Avatar
Retired Moderator
you guys keep on with WHP.. horsepower is a made up number.. your torque curve is what you and your tuner should be focusing on.
I have the numbers in my sig, our torque is around the same.. my HP numbers are only 248 and we would run side by side down the track.
Old Jul 20, 2010 | 05:40 PM
SAXON's Avatar
just because your tq is the same doesnt mean ****, its all about gearing and having the power put to the ground
and the victor x will only provide gains when reved high, i had one and compared to an itr/skunk2 it was horrible untill 430+whp and then the gains started showing
not to mention your head has gsr cams and who knows what valvetrain so you wont even get to the revs to get the full potential of the victor x
Old Jul 20, 2010 | 05:50 PM
Retired Moderator
^^ oh yea.. +1 gearing and traction is also a factor to consider. But WHP is still a made up number and doesnt mean ****
Old Jul 20, 2010 | 05:51 PM
true, the cams that are in the head are the only set back. head came off a boosted crx that reved to 9500 and ran 10's.
should have the car back tomorrow from the tuner to see what it does. my only fear is that tomorrow is going to be 95* with 90% humidity
Old Jul 20, 2010 | 05:54 PM
hey, it makes me feel better seeing 300something whp on a piece of paper saying that, and i can say i built the motor. i dont care if it is made up, makes me feel good.
93grayeg
25
Jan 1, 2012 04:40 PM
GEN2 LS
Mar 10, 2011 02:13 PM
dstappity
203
Feb 17, 2011 12:10 PM
tegra2G
Jun 16, 2008 03:30 PM
mrx
Oct 12, 2004 10:11 AM
