What engine oils are people preferring in their turbo engines? 2010-present
Old 07-11-2010, 10:22 PM
bLu92bUbbLe's Avatar
Default What engine oils are people preferring in their turbo engines? 2010-present
ive been running synthetic 5w30royal purple since ive been all motor...now im turbo...so my question is...whats the best oil for the turbo motor...i was told 10w40...what oil are u running and why?
Old 07-12-2010, 11:08 PM
phelpsj2's Avatar
Default re: What engine oils are people preferring in their turbo engines? 2010-present
bump
Old 07-12-2010, 11:25 PM
jdm inc's Avatar
brad penn http://www.t1racedevelopment.com/en/...acing-oil.html
BRAD PENN® Penn Grade 1® Racing Oils contain highly effective detergent and dispersant additives to guarantee exceptional engine cleanliness as well as oxidation and foam inhibitors that offer protection against thermal degradation and air entrainment. In addition to their unique base oil cut, increased concentration of “zinc” (zinc dialkyldithiophosphate a.k.a. ZDDP) provides outstanding anti-wear/anti-scuffing protection for engines employing either ‘flat tappet’ or roller cams. BRAD PENN® Penn Grade 1® Racing Oils have been evaluated by a number of premiere camshaft manufacturers with tremendous success. We here at T1 Race Development have seen an increase in cam and rocker life while using BRAD PENN® Penn Grade 1® Racing Oils. We now offer 10w30, 20w50, and the break in specific oils.
Old 07-13-2010, 01:53 PM
E85B18's Avatar
Depends on your bearing clearances. With ACL race bearings I ran 20w50 for years. Some say it's too thick but I had zero issues
Old 07-13-2010, 01:58 PM
CDecker0218's Avatar
Motul oil.
Old 07-13-2010, 02:06 PM
2000CTRSi's Avatar
10-30 or forty... thicker oil is better on high revving turbo cars imo
Old 07-13-2010, 04:45 PM
Retired Moderator
EsotericImage's Avatar
^^ +1
remember to change your oil every 1000 miles. Advanced auto has filter and 5qts oil for 17.00. and i change mine once a month..
Just another expense w/ premium fuel to keep our boosted rides going.
Old 07-13-2010, 04:47 PM
00-Civic-Si's Avatar
i change mine every 1000 to 1500 as well
Old 07-13-2010, 09:01 PM
joe111599's Avatar
I changed over to Royal Purple about a month ago and about 2-3 days later I spun #4 rod bearing! I totally blame that ****! I turned crank and installed new bearings and went back to Valvoline 10w30 with no issues. I have ran Valvoline for like 10 years no issues on all my cars....N/A and turbo! Never gonna even think about trying something different in the future...EVER! lol. I call that purple crap Royal Pain in the ***! haha.
Old 07-13-2010, 10:41 PM
blackcurrantgsr's Avatar
How do you know for sure it was royal purple that spun the bearing. On topic I use castrol syntec 10w-30.
Old 07-13-2010, 10:58 PM
99civicsiboosted's Avatar
mobile 1 synthetic 10w30 is what i use and i also change it about every month or so
Old 07-13-2010, 11:04 PM
kermit97's Avatar
i used napa 10-30 no issue at all for 5 years.
Old 07-14-2010, 04:53 AM
twkdCD595's Avatar
Brad Penn here...
Old 07-14-2010, 05:42 AM
TorganFM.'s Avatar
Whoa... thousand mile oil changes? Crazy.. I put 5k per change on Rotella T 10-40 for 60k miles, until my head stud broke and screwed the block threads up when changing the head gasket.
Old 07-14-2010, 05:53 AM
Same here
Old 07-14-2010, 05:59 AM
spoolin99si's Avatar
Royal Purple 20W-50. I change every 1500-2000 miles.
Old 07-14-2010, 07:29 AM
phatrick2332's Avatar
Changed every 5k.
Old 07-14-2010, 08:38 AM
sneakysneaky's Avatar
I use rotella synthetic and it lasts a while longer than
normal oil. Normal oil lasts about 1k till it pours like water
for me.
Old 07-14-2010, 09:04 AM
BlackT5's Avatar
I use Motul 8100, but you could use the 300V if ur a baller
Old 07-14-2010, 01:07 PM
Retired Moderator
Alot of people say this because RP doesnt carry the "seal of approval" for gasoline engines..I dont use RP stuff, i used the trans additive recently and after the change, it shifts alot worse than before.
Usually most motor oils have this approved seal, this is why i buy the cheap ****. valvoline, castrol, quaker (i dont use quaker state) is cheap, and when u change oil often, your not spending 30-40 per oil change. mine is 17.00 including filter.
Old 07-14-2010, 02:32 PM
turbo sol's Avatar
brad penn,
I choose it bc of the cam wear agents it contains that other oils don't. If you are running an after market cam I would look into it.
Old 07-14-2010, 04:06 PM
cool...so mobil1 synthetic 10w30 or 40 is ok...the thicker te better...i dont rev past 8k
Old 07-14-2010, 04:08 PM
i set the valve clearances oem spec...regular acl bearings...no race...
Old 07-14-2010, 04:10 PM
where do yall buy the motul and brad penn....
Old 07-14-2010, 04:50 PM
Retired Moderator
http://lmgtfy.com/?q=brad+penn+oil
Quick Reply: What engine oils are people preferring in their turbo engines? 2010-present
