1 to 1 fuel pressure regulator
Old Jul 20, 2010 | 01:09 PM
90Rexx's Avatar
Default 1 to 1 fuel pressure regulator
my tuner says i need a 1 to 1 fuel pressure regulator. what exactly is the difference between stock, and can someone show me examples of which ones are 1 to 1
Old Jul 20, 2010 | 05:37 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 1 to 1 fuel pressure regulator
how much power do you plan on making? difference is, a 1:1 reg will increase 1 psi per pound of boost.
i cant remember if a stock honda reg will or not. if you have access to a hand held vac pump, you can put pressure to it and see if it increases.
any decent aftermarket fuel regulator will step up 1:1
Old Jul 20, 2010 | 10:44 PM
hybrdthry911's Avatar
a stock honda fuel pressure regulator is 1:1.
he might not tuned hondas a lot if hes telling you to get something aftermarket. they are right you need to use a 1:1 regulator but he should know that already.
Old Jul 21, 2010 | 05:16 AM
dpetro1's Avatar
yup, oem fpr is 1:1.
what is your setup and what are you tuning with?
Old Jul 22, 2010 | 03:54 AM
90Rexx's Avatar
tuning with S300
setup is GT30R in a gsr stock block.
walbro 255
id1000's
looking for 400 whp
Old Jul 22, 2010 | 04:52 AM
dpetro1's Avatar
stock fpr should work just fine. many people, including myself, have made 400whp with oem fpr.
maybe you can ask the tuner why he suggested an aftermarket fpr. only reason i can really think of would be to increase the base fuel pressure.
Old Jul 22, 2010 | 05:30 AM
dancing_ninja's Avatar
Are they telling you to buy a regulator to bump fuel pressure? That would be the difference between stock and aftermarket.
Old Jul 22, 2010 | 10:18 AM
90Rexx's Avatar
i questioned whether or not i needed to buy a fuel pressure regulator, and he said i need a 1:1 regulator. thats as far as the conversation went.
Old Jul 22, 2010 | 10:50 AM
dpetro1's Avatar
well hopefully he was making the point that you dont need an FMU (rising rate regulator). but since you already have a 1:1 regulator then you should be all set
Old Jul 22, 2010 | 06:42 PM
redflaredcrx90's Avatar
you stock fuel system is good for at least 500 hp -fuel pump that you will have to change
Old Jul 22, 2010 | 07:54 PM
I just now say you are running ID's
The sheet that comes with the injectors has injector scaling that is based on fuel pressure. Increasing base pressure increases the hp capability on the ID's. I believe what he meant to say is you need an adjustable fuel pressure regulator that is 1:1. This way he can be sure that the scaling is dead perfect for the injectors assuring you the best idle, drive-ability, and linearity throughout the powerband.
DrivinVtec
Sep 30, 2007 08:04 PM
elpiar
May 30, 2006 12:25 PM
Bad-T
Jun 14, 2005 09:57 AM
phthalo
Jul 9, 2003 06:58 AM
redline201
Feb 6, 2003 08:02 PM
