Help on my ECU please?!
Old Jul 25, 2010 | 12:18 PM
CMTurbo99's Avatar
Default Help on my ECU please?!
I'm gonna be running a D16Z6 with between 7-8 pounds of boost and I need to figure out what program to run. People have told me to run Hondata S300 or crome.. Any one got some suggestions or know where I can get the program at a fair price?
Old Jul 25, 2010 | 12:22 PM
TDCTyler's Avatar
Default Re: Help on my ECU please?!
http://www.xenocron.com/ should have all you need (great website)
Old Jul 25, 2010 | 01:53 PM
CMTurbo99's Avatar
Thanks dude. You got any suggestions as to what tuning program I should run?
Old Jul 25, 2010 | 03:17 PM
TDCTyler's Avatar
No problem. I strongly recommend Hondata s300, Most Boosted Hondas run on that and any reputable tuner will probably tell you the same thing.
Old Jul 25, 2010 | 04:04 PM
boostedeg302's Avatar
Depends on the money you wanna spend. If you wanna do it right and have a great program, run hondata s300 or ectune. If money is a concern, then crome is a free program and a great choice for a mild power level. Who are you getting to tune the car?
Old Jul 25, 2010 | 05:26 PM
bigD's Avatar
Neptune hands down the best program I have used for the price http://www.hrtuning.com/
Old Jul 25, 2010 | 06:27 PM
Cant forget about neptune. Great pricing along with great tuning software
Old Jul 28, 2010 | 06:14 AM
CMTurbo99's Avatar
I'm not sure who I'm gonna have do my tuning. I live in vermont and from I hear, there's no one in vermont that does tuning. I also heard that if I run an FMU I should be fine without tuning as long as I don't run more then 7lbs worth of boost. That true?
Old Jul 28, 2010 | 07:31 AM
dpetro1's Avatar
No, FMU's are not a good choice for management. They are just a rising rate fuel pressure regulator that drastically increases fuel pressure. They cannot control timing or any of the other things that a program like hondata can.
Check out the Tuner Directory, maybe you can find something close enough.
https://honda-tech.com/forums/forced-induction-16/%2Anew-tuner-directory%2A-2349805/
Old Jul 28, 2010 | 09:27 AM
Turbo-LS's Avatar
In no particular order Hondata s300, Neptune rtp, ectune with an ostrich or deamon, Crome pro gold with an ostrich
personally I'd run the s300 cause it's what I like and very user friendly but so is Neptune and ectune just don't cAre for having to use an ostrich or deamon I like simple ready to go packages there usually less headache. I've tuned on s300 Crome pro Neptune and tinkered with ectune. Aside from Crome the rest are all comperable
Old Jul 30, 2010 | 12:26 PM
CMTurbo99's Avatar
So should I ditch the FMU? or could I get away with running it untill I can get one of the programs? I'll be lucky if I push 8lbs worth of boost to start. Or would the amount of boost I'm pushing matter when it comes to an FMU?
Old Jul 30, 2010 | 03:02 PM
SpeedFactoryRacing's Avatar
My advice would be to talk with your tuner and find out what they use. It all comes down to what they feel the most comfortable with. We use Hondata S300 and Neptune here at the shop most of the time. If you are looking to use something less expensive then Chrome is another choice. The FMU should go in the garbage, I am sure that you can get a basemap from someone that will be safe to run the motor until you can get it tuned just make sure they put a boost cut on the program.
Old Aug 20, 2010 | 04:22 PM
CMTurbo99's Avatar
So let me ask you this.... Is there any amount of boost that I could run on a stock ecu and fuel pump?
Old Aug 20, 2010 | 05:31 PM
bigD's Avatar
no
Old Aug 21, 2010 | 09:03 AM
CMTurbo99's Avatar
Ok. Cuz I've been told I could run a max of 5lbs on stock ecu and fuel pump and that it would be a good idea to run an fmu just to be safe. The person who I was told by said that i would run a little on the lean side as far as fuel goes, but they said I could get by like that for a little while.
93h2beg
Feb 13, 2013 11:56 PM
43MA
Jan 25, 2005 10:09 PM
1337 Si
Feb 11, 2003 05:29 PM
Gonzo
Feb 25, 2002 06:18 PM
f0de
Dec 13, 2001 03:46 AM
