is this oil return too high?
Old Jul 21, 2010 | 12:25 PM
BOOSTEd2's Avatar
Default is this oil return too high?
this is on my brothers d16z6 hatch. been having some oil return issues as far as leaking. return has a slight curve upwards. wanted to know if that could be causing the leak?
Old Jul 21, 2010 | 12:37 PM
dpetro1's Avatar
Default Re: is this oil return too high?
the angle of the line should not affect leaking. its probably leaking because you are using rubber hose & clamps. is that hose rated for oil?
Old Jul 21, 2010 | 12:44 PM
BOOSTEd2's Avatar
not sure if its rated for oil. i wasnt around when my brother put it on. but basically im just trying to help him out because he doesnt have the time to mess with his car.
Old Jul 21, 2010 | 12:49 PM
EsotericImage's Avatar
Retired Moderator
i would change everything to decent AN lines and a cut stainless hose.
Check out www.votionspeed.com for cheap fittings and hose.
Old Jul 21, 2010 | 01:08 PM
BOOSTEd2's Avatar
awesome site! looks like i'll be replacing his lines and the lines in my other 2 projects too! lol
Old Jul 21, 2010 | 01:16 PM
Retired Moderator
Old Jul 21, 2010 | 01:54 PM
Bailhatch's Avatar
Rubber hose is no more prone to leaks than AN fittings. Nearly all low pressure fluid connections on cars are just a hose over a barb and they don't leak.
It's leaking because you didn't put it together correctly not becasue you didn't use some red and blue compression fittings and hose rated for 200 times the pressure you have.
Old Jul 21, 2010 | 06:40 PM
BOOSTEd2's Avatar
How is it not put together correctly? I used this same turbo on my mr2 just fine. It wasn't leaking until after we dynoed it.
Dave_Dc2
Jun 19, 2010 03:56 PM
mafioso102
May 14, 2003 06:23 PM
lsvtec101
Jan 19, 2003 12:17 PM
C1V1CS1
Oct 16, 2002 12:23 PM
Jockobo
Jun 15, 2002 07:41 PM
