picking a engine to boost
Old Jul 16, 2010 | 08:41 AM
dsd1_209's Avatar
Default picking a engine to boost
im think bout doin an engine swap in my ek and dont no which one to do. im putting this in the forced induction section becuz ill be boostin that engine. which engine should i do.
1. lsvtech
2. ls
3. gsr
4. si
5. h22
i will be rebuild the engine completely and any info will be helpful
Old Jul 16, 2010 | 08:45 AM
EGhatch87's Avatar
Default Re: picking a engine to boost
what are you horsepower goals? budget? daily driver?
Old Jul 16, 2010 | 08:51 AM
dsd1_209's Avatar
bout 350-400 daily driver i dont no if thats to much hp for a daily driver not really worried bout budget but i wanna run it strickly pump gas
Old Jul 16, 2010 | 09:03 AM
joe111599's Avatar
I would probably go with a gsr myself. Once upon a time I had a gsr block and threw a b16 head on it and that was a great combo. With the gsr block you already have vtec so all you have to do it throw the head on. With the ls/vtec you have to run all the lines and tap **** for vtec. Just easier and works great. I only did it because I had the block and head sitting in my garage and needed a motor so I threw them together. A straight gsr swap would be great.
Old Jul 16, 2010 | 09:07 AM
sneakysneaky's Avatar
A stock gsr would probably be the most reliable for
the money you would have invested.
Old Jul 16, 2010 | 09:10 AM
dsd1_209's Avatar
thanks for the info would you keep the gsr head or a b16
Old Jul 16, 2010 | 09:15 AM
boostedeg302's Avatar
If it were me, I would throw in a gsr. Its gonna cost a lot more than an ls but in the long run it will be worth it. You can make 350whp no problem with a stock gsr. My next choice would be an ls engine. You can make 300whp fairly easily and they are cheap as **** and readily available. Basically, it comes down to what you are willing to spend
Old Jul 16, 2010 | 09:22 AM
A gsr head is fine, I would just run it stock.
Old Jul 16, 2010 | 09:26 AM
dsd1_209's Avatar
wat bout ecu gsr with a hondata chip, a standalone or wat do you guys suggest
Old Jul 16, 2010 | 09:36 AM
TorganFM.'s Avatar
D16Z6
engine and trans, $200
fjt kit, $600
turbo, $300
machine work, $200
20lbs turn ya out, priceless
Old Jul 16, 2010 | 09:41 AM
AlexDphoto's Avatar
GSR
more displacement than the B16, better flowing head than an LS, and it doesnt have FRM sleeves like the H22.
blu3fan
Mar 8, 2012 10:28 AM
jdmgeek21
Dec 3, 2008 04:38 AM
skam8787
Nov 16, 2007 05:46 AM
96civic_hb
40
Jul 3, 2007 10:27 PM
shannon
Mar 3, 2004 07:42 PM
