Fuel rail issues.
Old Jul 7, 2010 | 03:44 PM
10sec4door's Avatar
Default Fuel rail issues.
Well I have precision 1000cc, IDK if its the fuel rail but keeps leaking from the injectors where the go into the rail. I checked the orings. all looks fine. Any clue? any way prob just gonna sell the whole setup cheap if I cant figure it out.
Old Jul 7, 2010 | 03:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Fuel rail issues.
pics may help. its hard to "see" whats going on with out seeing whats going on.
Old Jul 7, 2010 | 04:29 PM
HiProfile's Avatar
Sometimes you have to remove the spacers between the rail and manifold, or reduce their height a bit. The injectors may be a little shorter than stock, and the o-rings are right at the edge. They also could have machined the hole too large, your o-rings are too small (not OEM, too old, or injector uses a thicker o-ring), or you need the rubbery spacer that goes on the injectors between the rail & connector.
Old Jul 7, 2010 | 06:58 PM
Project_EK's Avatar
get a pic of where it's leaking...i'd bet the rubber o-ring is bad on the injector/s! get some o-rings and oil them up before pushing the injector back into the rail
Old Jul 8, 2010 | 07:05 PM
10sec4door's Avatar
ama try bigger o rings. I know the ones on there are good maybe too small. I feel like shooting this car nothing easy as soon as I fix one problem another rises. lol guess thats the life of building these cars. I bet if i pieced it together from the junk yard it wouldnt of given me any issues lol.
Old Jul 9, 2010 | 07:30 AM
Deatschwerks's Avatar
You should be able to find a decent selection at your local automotive retailer. I used to work at NAPA before coming to DeatschWerks, and we had a couple of large wall mounted "parts" boxes with a large assortment of ac/nitrile/viton o-rings.
Old Jul 10, 2010 | 11:32 PM
EsotericImage's Avatar
Retired Moderator
Did u use grease or vaseline on the O rings when your pushing them on the rail?
Old Jul 11, 2010 | 08:46 AM
10sec4door's Avatar
yup.
410ruga
Apr 10, 2014 03:46 AM
ekHatchdom0
Mar 11, 2010 07:24 AM
ThePro
Jun 16, 2005 08:58 PM
Cowboy
Mar 18, 2004 05:56 PM
FOrSfEd
Jan 23, 2004 05:34 AM
